Random Little Question Thread
Old Dec 5, 2012 | 04:20 PM
  #7846
TORETTO's Avatar
pretty much.
Old Dec 5, 2012 | 04:28 PM
  #7847
ishiftinheels's Avatar
Teh Redhead Moderator
Old Dec 5, 2012 | 04:54 PM
  #7848
My Key's Avatar
I agree. Sea Foam™ is where it's at.
Old Dec 5, 2012 | 05:06 PM
  #7849
pande.acc@gmail.com's Avatar
Thank you.
I will use Sea Foam only.
Do you think this will solve my "GURR" sound problem?
Please advice on Compressor rod bushing. Do i need to replace it.
Its very expensive.
Old Dec 5, 2012 | 05:19 PM
  #7850
G35Papa's Avatar
Originally Posted by Muney2bmade
Can I buy two pairs for the bottom set of lights as well?
Mine are two different colors and I don't really like it.
The bottom bulbs (fogs) are H1 on 06/07 coupes
You can find all your answers here
https://g35driver.com/forums/lightin...ent-guide.html
Old Dec 5, 2012 | 09:10 PM
  #7851
NFSP G35's Avatar
? = 2B || !2B
Try turning the AC completely off andsee if the sound goes away
Old Dec 6, 2012 | 08:07 AM
  #7852
cto917's Avatar
Originally Posted by pande.acc@gmail
Thank you.
Its very expensive.
Jesus, 500 bucks?? Nothings going to kill you if you don't replace em yet but if its badly damaged it might create some suspension wobble causing premature wear to other suspension parts and or tires. Bring it to a reputable auto shop for cheaper prices. If u wanna diy I'd rather replace the whole rod unless you have a press.
Old Dec 6, 2012 | 08:15 AM
  #7853
cto917's Avatar
Thank you.
Its very expensive.
And um, gurr? Lol are you SURE its engine? Maybe transmission. As far as 90k service goes...I wanna say bring it somewhere else. It's not like its still under warranty and might find something else wrong to replace through the warranty. If you've taken care of you engine with oil changes at appropriate times you shouldn't need seafoam yet. And unless you're running on low octane gas with gunk buildup. Transmission fluid change jiffy lube does it for like 120 bucks. Ac service shouldn't be necessary unless you're using ac everyday for like 10 years. Lol trust me I use to work at a place that does ac service telling people they needed it but is still like half full of Freon. *
Old Dec 6, 2012 | 09:48 AM
  #7854
TunerMax's Avatar
G35
could be an exhaust leak or a BILLION other things, I agree that you need to take it toa reputable shop.
Old Dec 6, 2012 | 10:04 AM
  #7855
Peoria35sedan's Avatar
Thank you.
Its very expensive.
Sea Foam, Really?
Is this place is turning into a Honda forum?
YES you need to replace your damaged suspension components
Old Dec 6, 2012 | 10:48 AM
  #7856
TunerMax's Avatar
G35
He never said he needed a compression rod bushing, it sounds like someone just suggested he do it for the sake of 'doing it'.
If it's not broke, dont fix it.
Time to take your car into a good shop for an inspection.
Old Dec 6, 2012 | 11:00 AM
  #7857
I figured the dealership told him to replace them, my bad. At 90K good chance they're done, needs to be checked for sure.
Old Dec 6, 2012 | 11:09 AM
  #7858
TunerMax's Avatar
G35
could be, you may be right.
Old Dec 8, 2012 | 02:04 PM
  #7859
grdane101's Avatar
19 inch wheels on a 2003 g35 coupe?
Hello everyone i am going to be getting new tires and wheels on my 2003 g35 coupe and im wondering if i am able to get 19 inch wheels. I have stagered 17s right now. would i need to get stagered 19s and if so what size would be the correct size. also Is it true that the bigger size of tire increases handling? I am leaning towards getting bridgestone potenza pole postion to go with these wheels. Does any have any experience with these tires? if any there are any better tires for performance wet and dry please recomend.
Old Dec 8, 2012 | 02:14 PM
  #7860
350sky's Avatar
You can definitely go 19s. 05-07 G35 Coupes came in OEM 19s.
As for handling, I believe 18s are best since they are lighter than 19s. 19s also give you a harsher ride.
Hope this helps!
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
