Random Little Question Thread
Old Jan 10, 2013 | 09:23 PM
  #8296
DVG's Avatar
DVG
Originally Posted by JDMswagSerf
me too!
now it makes sense why I couldn't see at night when I turned the low beams on and I had to turn the foglight switch. I was like wtf.
I guess both bulbs are missing or the left side is a bad bulb. cuz only the city lights turn on when I flip the light switch, and 1 city light doesn't even work!
I was driving just on foglights.
The city lights arent good for anything except people being able to see you when your bulbs are burned out. I just took mine out, nasty yellaw!
Yeah you need some low beam bulbs ASAP
Thats kind of messed up that someone would take out the bulbs before selling the car, bad karma. Maybe they thought they were worth a lot (They cost a lot at the dealer, but what doesnt)
Here: http://www.theretrofitsource.com/pro...ducts_id=19006
Note: the reason the only options are 4300K, 5000K, and 6000K is because these are the only bulbs that are good for actually seeing the road.
MAKE ABSOLUTELY SURE YOU DO NOT TOUCH ANY OF THE BULBS IN THE HEADLIGHT WITH YOUR FINGERS! THEY WILL EXPLODE!
Old Jan 10, 2013 | 09:26 PM
  #8297
dominate's Avatar
Originally Posted by dominate
Im having my nismo rear from ionic painted, and i want the scheme to be like OEM. Should I ask for the lower part to be satin black? Flat black?
bump
Old Jan 10, 2013 | 09:27 PM
  #8298
DVG's Avatar
DVG
bump
Im going to guess flat black
Old Jan 10, 2013 | 09:40 PM
  #8299
JDMswagSerf's Avatar
okay thanks for the link ha.
so remember I said I ordered fog bulbs 3000k hid simulating bulbs?
the seller set me the correct size.
but they are freaking blue!!!!!
so now I gotta wait for the hid bulbs to get here and the 3000k foglight bulbs too!
I'm just gonna put everything back together till I for sure have the correct parts.
beyond mad.
but anyways. you like my plastidipped wheels?
Old Jan 11, 2013 | 01:02 AM
  #8300
TunerMax's Avatar
G35
Hail plastidip
Old Jan 11, 2013 | 02:57 AM
  #8301
Airic214's Avatar
bent rim :(
so guys when i was driving the car kept shaking and when i went to look at one of my wheels i heard air coming out. Upon further inspection i see that my rim is bent ! what do i do?!?!?!?
Old Jan 11, 2013 | 03:05 AM
  #8302
The Stimulation's Avatar
Pretty obvious...but you'd get the wheel fixed and inspect the tire to make sure it's still good.
Old Jan 11, 2013 | 03:08 AM
  #8303
Airic214's Avatar
how much will it cost to fix the rim
Old Jan 11, 2013 | 03:20 AM
  #8304
Varies on the shop and what needs to be done. Looks minor, looks like inner barrels so no refinishing so I'd say 60 bucks tops.
Old Jan 11, 2013 | 10:32 AM
  #8305
DVG's Avatar
DVG
Originally Posted by Hinnenk1amp
I know a little, but i've been reading a lot trying to learn as much as possible before I put my suspension together.
more spam.
always linking to "frontieracademy" like the other spammers
https://g35driver.com/forums/search....rchid=14236649
It seems like they are making throw away accounts, they make a bunch of posts and then never post again.
Old Jan 11, 2013 | 06:13 PM
  #8306
In that video he removes a piece from the headlight.
But he has a coupe and I like the way the headlights came out!! All blacked out.
On my 04 sedan. If I bake them and I pry them open. Will a piece like his pop out? And if I paint the piece from my headlight, will it look like/similar like his? Thanks.
Old Jan 11, 2013 | 06:15 PM
  #8307
DVG's Avatar
DVG
http://m.youtube.com/watch?v=DG4LcCDdVZo
Yes and yes, you can actually do this to most cars. I have found Gs are forgiving in resealing. Proceed at your own risk, there is a DIY somewhere.
Old Jan 11, 2013 | 06:56 PM
  #8308
Okay thanks.
And it'll look similar to your right? Because you have the black housing right.
Ill try to find the DIY.
Old Jan 11, 2013 | 09:18 PM
  #8309
NFSP G35's Avatar
? = 2B || !2B
Yes, but do it the right way (no plastidip in headlight)
https://g35driver.com/forums/lightin...eadlights.html
Old Jan 11, 2013 | 09:54 PM
  #8310
dj714's Avatar
Is it easy to put the lights back to together? I'm thinking about doing this my headlights have condensation inside and look like they can use a good cleaning rather then buying new ones
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
