Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Mar 14, 2013 | 12:20 PM
  #8776
Peoria35sedan's Avatar
Originally Posted by beriously
whenever i drive my g35 any little rock or bump that i hit my car would start shaking, and when I was driving home the other day it was raining hard and i had to drive 40 because my car would shake and jerk to the sides.
I still need to get my wheels realligned, but as for smoothness what can i do? "noob driver"
Would help to know about the car, is it lowered? if yes, how? have you done any suspension work like sway bars, urethane bushings, wheel bearings. There are a ton of variables, start by taking it to an alignment shop they'll probably come back with a list of repairs needed.
Old Mar 14, 2013 | 06:33 PM
  #8777
JDMswagSerf's Avatar
what's up. you guys miss me? lol jk.
today I was driving. well like 5 min ago. and it's 90 degrees out and I ha my ac on I think it was full blast or 1 click below full blast. anyways. I noticed my temp gauge is higher than normal! the needle was about 55-60% on the gauge! I got sated and shut the ac off and it droppe down to what it's always at. 40-45% on the gauge.
so. has this happened to anyone else? is it normal or is something wrong. I check y reservoir and there was plenty of coolant there.
the car is forsale btw.
Old Mar 14, 2013 | 07:43 PM
  #8778
TORETTO's Avatar
lol.
Old Mar 14, 2013 | 08:08 PM
  #8779
Originally Posted by TORETTO
lol.
I am selling because it's AT haha.
Old Mar 14, 2013 | 08:23 PM
  #8780
Wi-Z_Sam's Avatar
Specifically what shaking? If its just the wheel definitely get an alignment and wheels balanced
Old Mar 15, 2013 | 04:52 PM
  #8781
Reedtc's Avatar
When I replace my transmission, can I drive it to the dealer to get the computer reflashed or does it have to be towed ?
Old Mar 15, 2013 | 06:58 PM
  #8782
hopesNdreamz's Avatar
dont mean to go off topic here, but i got a annoying problem with my power windows.
when i pull the tab all the way back to auto roll my front driver side window up it will go all the way up and then automatically go back donw about half of the way.
but when i pull and hold the tab it goes all the way up and stays up...do i have to replace the whole motor in the door? or is there a cheaper way i can fix it... any help will be greatly appreciated!! thanks!!
Old Mar 16, 2013 | 11:07 AM
  #8783
nazc0's Avatar
2006 Vortech supercharged Sedan
if its the same transmission i dont think it needs anything but im not sure wait for someone who definetaly knows but i dont think it will need to be towed
Old Mar 16, 2013 | 01:14 PM
  #8784
Blue Dream's Avatar
I drove ttrank's car solo
Search Driver for "window motor reset". There's a procedure to follow that might fix your issue but I can't remember what it is.
Old Mar 16, 2013 | 02:00 PM
  #8785
okay cool, you wouldnt happen to know where i could find that procedure would you? if not, its cool Blue Dream...thanks!!
Old Mar 16, 2013 | 03:16 PM
  #8786
Airic214's Avatar
does anyone know how to move the side mirrors 04 g35 sedan
Old Mar 16, 2013 | 03:20 PM
  #8787
Wi-Z_Sam's Avatar
Look under the wheel a little to the left there is a **** there
Old Mar 16, 2013 | 03:48 PM
  #8788
Airic214's Avatar
6 month mystery has been solved!
Old Mar 17, 2013 | 08:10 PM
  #8789
thegreatkwijibo's Avatar
I'm installing a MD 5/16" spacer and was wondering if anyone else had a problem getting the studs out of the plenum. The 4mm was too big and started round off the top of the stud. The instructions said something about using both nuts to get it off, but I'm not sure what they did to get it off. If anyone knows what I can do to get them out that would be much appreciated.
Old Mar 17, 2013 | 08:16 PM
  #8790
DeBlaca's Avatar
Searched (a little) and didn't find anything besides this thread. If I were to get OEM 19's to replace my current 17's, would I have to get the fenders rolled? My car isn't dropped.
Edit: Failed to see this was in the sedan section, duh. Sorry.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
