Random Little Question Thread
Old Oct 1, 2013 | 03:41 PM
  #9646
herrschaft's Avatar
Originally Posted by dofu
The consensus is if you haven't been changing out the transmission fluid regularly, it's better to just leave it.
WHAT???
G-Dirty: Just change the fluid
Old Oct 1, 2013 | 03:59 PM
  #9647
dofu's Avatar
20 Year Member
Originally Posted by herrschaft
WHAT???
Supposedly, a bulk of transmission issues start because the owner waited until over 90k to change the fluid.
Transmission fluid gets a little dirty, but most of it is from the initial break in of the transmission, so it's already been dirty for about 100k miles and only a minute fraction of it is from wear and tear. The fluid doesn't go bad, it won't lose viscosity over time like oil does, so leaving it in there will be fine.
But that's what they say. I never said not to change the fluid, I was just answering why they say that. I changed the fluid and filter in my IS at about 100k anyways and everything is fine.
Old Oct 1, 2013 | 04:03 PM
  #9648
nathan1726's Avatar
2003 g35 sedan exhaust tip
i have been searching everywhere for exhaust tips for my 2003 g35 sedan mine are real gross looking. any suggestions??
Old Oct 1, 2013 | 04:04 PM
  #9649
dofu's Avatar
20 Year Member
I remember someone was using exhaust tips from the Altima because they just looked a lot nicer.
Old Oct 1, 2013 | 04:07 PM
  #9650
nathan1726's Avatar
thats not a bad idea. ill look into that thanks
Old Oct 1, 2013 | 04:11 PM
  #9651
nathan1726's Avatar
do you happen know know which year of altima tips were used? and where he got them from??
Old Oct 1, 2013 | 04:14 PM
  #9652
dofu's Avatar
20 Year Member
https://g35driver.com/forums/intake-...aust-tips.html
Old Oct 2, 2013 | 03:24 PM
  #9653
wasjr's Avatar
I can’t speak to more recent transmissions and transmission fluids but years ago I knew a very reputable family who owned several transmission shops. They said that if the fluid had never been changed and there was an issue with the transmission, it was probable that gear shavings and the gunk was holding the transmission together. After changing the fluid on high mileage cars and then being accused by the car owner of intentionally causing transmission damage when the transmission essentially fell apart and needed a re-build, they started refusing to change the fluid on high mileage vehicles unless the transmission had been previously serviced at their shop.
Old Oct 3, 2013 | 05:23 PM
  #9654
Big Booty Trudy's Avatar
I hear this click that I don't like when putting the car into drive while having my foot on the brake. It comes from under the car maybe around the drivers seat. Maybe a little more towards the center. Anybody have some input as to what it could be? I could provide a video. Thanks guys.
Old Oct 3, 2013 | 05:27 PM
  #9655
TORETTO's Avatar
Doesn't the auto trans have some sort of lock that prevents you from moving from Park or something into Drive without stepping onto the brake pedal?
That the click you're talkin about?
Old Oct 3, 2013 | 05:39 PM
  #9656
Oh no. It's coming from under the car.
Old Oct 9, 2013 | 06:21 PM
  #9657
Lartytiejdke3's Avatar
non rev up and revup engines use the same spark plugs correct?
Old Oct 9, 2013 | 07:11 PM
  #9658
G_DiRTY5's Avatar
WHAT???
Thanks for the detailed input guys. Unfortunately I am not the first owner of my G so I have no idea if or when the tranny fluid has been changed. I think I'm gonna change the tranny fluid after I install Sean's grounding kit just to see if his kit makes any difference on the tranny.
On a side note, I went for a test drive with my mechanic in my car and he said he didn't like the "sticky"/delayed shifting. But this was right after some spirited driving and it's natural for the G to act this way... right?
Old Oct 9, 2013 | 08:19 PM
  #9659
herrschaft's Avatar
^The last time my tranny felt like it was delayed/slipping it was because of low fluid.
Old Oct 10, 2013 | 03:08 AM
  #9660
dofu's Avatar
20 Year Member
I'm not sure about that one - rev up motors have more advanced timing so the plugs for rev up motors might be a step colder to help prevent detonation. If you are modded, one step colder is not a bad thing.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
