Random Little Question Thread
Old Dec 29, 2013 | 05:00 PM
  #9841
Urbanengineer's Avatar
Originally Posted by cobycoconut
I want to change all lights on dash white! I know you can on the cluster. But what about all the way down the center dash!? I'm just really tired of the orange color. I just want to know if this is possible and how much it would cost??
I have heard of two people that have done this, and they spent countless hours on it. Learn to live with the unique orange i
Old Dec 29, 2013 | 10:13 PM
  #9842
dofu's Avatar
20 Year Member
Changing the color of the center console is a lot easier than changing the color of the cluster. Do a little research to find out for yourself.
Why would you want to change it anyways? The orange color is easier to see than red, but much easier on the eyes during long drives than white, blue, or purple. Infiniti chose not to go the path of new LED technologies with this for that very reason.
Old Dec 29, 2013 | 11:02 PM
  #9843
TORETTO's Avatar
marcus cooke did it right?
pain in the *** iirc.
Old Dec 29, 2013 | 11:03 PM
  #9844
NjMatteSedan's Avatar
Will brake pads for oem rotors fit on my aftermarket drilled rotors on my 03 sedan?
Old Dec 29, 2013 | 11:10 PM
  #9845
NFSP G35's Avatar
? = 2B || !2B
yes, always
Old Dec 29, 2013 | 11:11 PM
  #9846
NFSP G35's Avatar
? = 2B || !2B
this too is correct
Old Dec 29, 2013 | 11:13 PM
  #9847
TORETTO's Avatar
Old Dec 30, 2013 | 06:12 PM
  #9848
silver9's Avatar
I tried to put a 15mm spacer on the rear wheel but surprisingly enough, the wheel wouldn't sit flush over it. The original bolts on the hub won't allow it as they are sticking out further than the spacer. What gives?
Old Dec 30, 2013 | 06:16 PM
  #9849
TORETTO's Avatar
What wheel do you have?
A lot of wheels have spaces for studs go to if using a spacer.
Such as
Old Dec 30, 2013 | 06:23 PM
  #9850
silver9's Avatar
I have holes instead but the nuts on the spacer might be too big. I guess that was the problem. Thanks
Old Dec 30, 2013 | 06:24 PM
  #9851
TORETTO's Avatar
Yes, I think your nuts are too big.
Old Dec 30, 2013 | 06:52 PM
  #9852
Frankieg35's Avatar
Thats what she said..
Old Dec 30, 2013 | 07:13 PM
  #9853
cobycoconut's Avatar
Well I mean. I want to go with a white because I don't know. It looks nicer to me. I'm a bit of an OCD Freak and i like things to match and the orange throws it off. I want a white but I don't want a bright bright white.
Old Dec 30, 2013 | 11:33 PM
  #9854
TORETTO's Avatar
Where the hell does one get replacement brushes for the Dremel 4000? Dremel doesn't even list any for it. And all the other sites saying they have brushes for the 4000 are out of stock.
Old Dec 30, 2013 | 11:52 PM
  #9855
TORETTO's Avatar
Screw it, instead of spending $10 to order replacement brushes from Dremel, I'm buying a 80 piece Dremel knockoff tool kit from Harbor Freight for $10. Only gonna use it once, and comes with 90 day warranty.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
