Random Little Question Thread
Old Apr 25, 2015 | 02:24 PM
  #10306
nazc0's Avatar
2006 Vortech supercharged Sedan
Old May 17, 2015 | 04:37 PM
  #10307
dominate's Avatar
I was involved in a small collision on the front bumper driver side. It caused my passenger side HID to go out, but it went back on after turning it off and on. Now, when going over bumps, it frequently goes off again and I need to turn the switch off and on to get it back on. Any ideas? Igniter was attached and the wiring to the ballasts look connected properly.
Old May 17, 2015 | 11:54 PM
  #10308
saywat?'s Avatar
U guys really should. Hit up ur local dealers online site if they have one. Most do. And most prices are comparable online.
Old May 18, 2015 | 07:48 AM
  #10309
Justice06RR's Avatar
Hard to tell what the issue is unless you completely inspect the hid kit.
Same thing kinda happens in my old Honda Accord before. The right side hid bulb would not turn on all the time. It was also involved in a minor front end collision. So I just turn it off for a minute and turn it back on. PPssibly something loose somewhere
Old May 18, 2015 | 11:39 AM
  #10310
KillerMichaE-lp's Avatar
On a 5-AT is there anything wrong with leaving your car in M-5 and driving around? It seems to automatically shift when necessary, like if I forget to shift down at a red then start driving it goes through the gears like in D.
Old May 18, 2015 | 01:42 PM
  #10311
NFSP G35's Avatar
? = 2B || !2B
^What year?
If 04.5 or later, the shift logic changed.
Before that, there's really no difference between M-5 and "D"
Old May 18, 2015 | 02:21 PM
  #10312
Originally Posted by NFSP G35
^What year?
03.5. Thanks for the heads up
Old May 18, 2015 | 07:32 PM
  #10313
6mt_Ramon's Avatar
Trunk light
I recently bought an 05 g35 coupe. I noticed the bulb in the trunk was missing so I bought an led t10. I put it in there and it worked but as I was closing it, I was noticing that it didn't turn off while I closed the trunk. I figured that's why it was missing in the first place. Has anyone else experienced this? I took it back out in fear of it draining my battery
Old May 31, 2015 | 04:13 AM
  #10314
rodriguezdanilo's Avatar
Still shopping for my g35. My price range tells me the one I get will most likely have at least 80k miles. (will be financed)
Done a lot of research on what to expect and am willing to deal with the brake and suspension issues. What concerns me of course is the old OC issue.
When buying used will a plug check and compression test tell me if it has the issue?
I'm actually hoping to find the short block replacement in it's service records. I feel like a 100k g35 should have either had it fixed already or at least be showing symptoms without doing an OC test, which is impossible if I dont yet own the car.
Old May 31, 2015 | 11:23 PM
  #10315
CG4DR's Avatar
Tried looking for reviews and answers but no luck.. Are the Tomei 272*'s an aggressive cam setup? And are they any good?
Old Jun 8, 2015 | 12:30 PM
  #10316
drifterxG's Avatar
Anytime you go over 11mm of lift, it's recommended to upgrade the valves, valve springs, rod/head bolts, and a tune.
The Tomei's have been tested for decent results, but the JWT S2's prove better on NA build. If you're boosted, then I recommend JWT (Jim Wolf Technology) C2 cams. Your revs can be raised to 7500rpm. IF you do go with JWT, try to get JWT springs to match.
Old Jun 9, 2015 | 06:31 PM
  #10317
CG4DR's Avatar
Originally Posted by drifterxG
Anytime you go over 11mm of lift, it's recommended to upgrade the valve springs, rod bolts, and a tune.
Going to stay N/A. Motor is 2005 RevUp
0.020", 11:1 Pistons
Mill, P&P the heads
Long tube headers
Already has other mods to make 270whp/250wtq.. I was hoping to hit somewhere closer to or over 300whp
Old Jun 16, 2015 | 12:54 PM
  #10318
leo38cheng's Avatar
*looking for someone to help with fixing the lock actuator on the 2005 G35 Coupe -- in NYC -- anyone? any local mechanics here?
Old Jun 18, 2015 | 03:32 PM
  #10319
blitzace137's Avatar
I'm looking to buy the illusion lip and found out Duraflex makes them and there is a eBay brand. Andys is selling Duraflex brand for around $220-230. Ebay brand goes for around $114.00. Is it worth buying the eBay one or should I buy the better one?
http://m.ebay.com/itm/151689550031?nav=WATCHING_ACTIVE
Old Jun 18, 2015 | 03:38 PM
  #10320
saywat?'s Avatar
id buy it from ebay. the design is simple enough that they can really screw it up imo. i think those lips are so ugly but very popular idkw.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
