Random Little Question Thread
Old Apr 23, 2017 | 01:42 AM
  #10471
BradMD_96's Avatar
Surely some have seen this before..... probably bringing up old news
https://imgur.com/a/B6vTO#Tcc6NnT
Looks more like a G35 with R35 bits stuffed into it
Old Apr 25, 2017 | 07:44 AM
  #10472
Urbanengineer's Avatar
Anyone ever replace the rack and pinion seals on the G and succeed? I really don't want to spend $300 on a new rack because a gearbox leak - but steering is heavy .
Old Apr 27, 2017 | 12:43 AM
  #10473
mrbrindle's Avatar
Window regulator same on G35 and 350z?
Hey all, quick question here. I have a 2004 G35 coupe and I'm looking at getting my window regulator replaced, does anyone know if I can get away with buying a window regulator for a 350z? They seem like the same part but I can't seem to find a part number match, anyone have some knowledge for me? Thanks.
Old Apr 27, 2017 | 04:43 AM
  #10474
Blue Dream's Avatar
I drove ttrank's car solo
^^You might want to post this in the Coupe random question thread. This is for the 4 doors if you didn't notice.
Someone here might answer for you though.....
Old Apr 27, 2017 | 09:20 AM
  #10475
Rockauto . Com
Compare part #'s.
Old May 29, 2017 | 04:22 PM
  #10476
MrTBahgs's Avatar
06 G35X with Bluetooth phone that is having issues recently. I am trying to see if a fuse or ground is faulty, the Bluetooth system is known to ever go bad, or my phone somehow got an updated that broke things.
I've never had an issue until a few days ago and now it is repeating. The amber light phone indicator will just continue blinking the whole time driving and it no longer let's the phone button on the steering wheel do anything. Sometimes it seems to connect fine and stay solid, but less often than constant blinking.
I have tried turning Bluetooth off and on or starting the car with it initially off, but nothing is working. Since the button on the steering wheel won't let me access anything when this bug is happening I cannot try to re pair my phone.
The only thing that has changed in awhile is I did have an Android update last Friday. Could a phone update really have made things not work all the time, but still some of the time? Id think it would be all or nothing.
The blinking makes me think it is trying to connect and sort of sees the phone, but then again I have tried with Bluetooth off and then starting the car and it all blinks longer than normal.
Even if I can get the phone button to work after a few tries, i don't have another phone to try a fresh pair and rule out my personal phone.
Does anyone have a fix or previous experience with the phone system failing?
Old Jun 8, 2017 | 10:53 PM
  #10477
MrTBahgs's Avatar
Bump for the above, no one has had that issue before?
Maybe bluetooth phone was on '06 and above so I have less potential users to reach?
Old Jun 8, 2017 | 11:01 PM
  #10478
calcul8's Avatar
I can haz potato?
sabertooth tiger
The only issues I've ever experienced were the bluetooth system periodically not connecting to my phone (7+ different phones from multiple different manufacturers over the last 11 years)
Old Jun 9, 2017 | 05:23 PM
  #10479
MrTBahgs's Avatar
Thanks for the reply. By not connecting did it also keep blinking amber the whole time driving or just stay dark? To clarify for me, these phones all connected at some point and didn't work periodically, or some never worked with the car?
Old Jun 9, 2017 | 05:30 PM
  #10480
calcul8's Avatar
I can haz potato?
sabertooth tiger
All the phones connected most of the time, but periodically randomly would not. As for the blinking, I think I only experienced that when I was trying to place calls too quickly and/or hanging up using the steering wheel-mounted buttons and the system was having trouble keeping up and may have once gotten "stuck" in the confused blinking mode. Turned off the engine, turned it back on, no more issue.
Old Jun 12, 2017 | 10:14 PM
  #10481
calcul8's Avatar
I can haz potato?
sabertooth tiger
Note: this also happened with service loaner vehicles that I had so I think it's more of an issue with infiniti's bluetooth radio that they were using at the time
Old Jun 13, 2017 | 07:28 AM
  #10482
ovsplayer's Avatar
I have an 06 G35x and my Bluetooth also has been having this issue lately as well, connecting to a S7 with OS 7.0. may just turn off the bluetooth because of the constant blinking light once it does connect. I do have a Bluetooth OBDII connected and will try to disconnect that and see if that is causing any interference.
Old Jun 13, 2017 | 05:55 PM
  #10483
MrTBahgs's Avatar
Ohh I am glad you saw this then because I am personally thinking it may have to do with my phone itself since the latest update since I have never once had a single issue with bluetooth before this. As in like the newest of phones may run a non-compatible version of bluetooth.
I have a 2 year old Samsung Galaxy S6 that is also running Android 7.0 and only updated to that semi-recently. Was your prior phone trouble free assuming you had the G with an older phone?
I do not have an older phone to try out and see what happens, but at least the blinking thing isn't happening all that much now, certainly less often, but still pops up at times. The other issue though is that certain calls do not work and I have to switch to privacy mode because I hear indistinguishable garble through the speaker and I do not think the listener hears me until I swap to my handheld.
Basically a lot has changed since the last update or two so it seems like that would be the culprit, but I have had other little electronic failures and issues with the aging G that it wouldn't surprise me too much if the bluetooth was also dying.
Old Jun 29, 2017 | 09:48 PM
  #10484
Comatones's Avatar
Radiator cap part
Hey guys, I'm new on here. I have been having a ton of trouble locating the name of a part in my cooling system. Does anyone know the name of the part the radiator cap is connected to????
2007 g35s sedan
Old Jun 30, 2017 | 05:55 AM
  #10485
Blue Dream's Avatar
Not sure on the 07, 06 and down the filler neck is part of the radiator.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
