Random Little Question Thread
Old Nov 12, 2017 | 01:20 PM
  #10516
ronnieballgame's Avatar
Yeah, for the passenger side, just the forward/reverse and tilt switch.
Old Nov 12, 2017 | 03:14 PM
  #10517
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Ahh yeah, that looks like mine then
Old Nov 12, 2017 | 04:02 PM
  #10518
You think the one for the Z would work? I wouldn't think that they would make a different switch for the passenger side of a G
Old Nov 12, 2017 | 06:14 PM
  #10519
cleric670's Avatar
BANNED!!!
As long as you need a black or grey colored one it should be fine, I don't -think- the 350Z was offered with anything other than those colored switches, their interior colors were "burnt orange" "frost" "black something something" and "nismo" and they all used a black switch except for frost which was a grey colored one.
Old Nov 12, 2017 | 07:08 PM
  #10520
I'll give it a shot. I need black, I think the only difference is the actual switch itself is silver and the z looks black but if it works I can live with it
Old Nov 29, 2017 | 01:47 PM
  #10521
Efitz19's Avatar
Car making weird slight jerk 2003 G35 sedan
I was driving the other day and I started having a really rough idle when i came to a stop light, it didn't sound right when I was driving again and it was weaker, and threw up a check engine light so I put a code reader in and it was for a cylinder 5 misfire, so I looked into it and replaced the spark plug for that cylinder, the code doesn't get thrown up anymore and when I drive it's completely smooth and same power, but when I come to a stop it will randomly have a very light jerk barely even noticeable and no codes pop up, I was thinking it could just need a whole new set of spark plugs. Anybody have any ideas?
Old Dec 1, 2017 | 04:22 PM
  #10522
cleric670's Avatar
BANNED!!!
If you have 60k+ on the plugs OR if they're not OEM plugs then just replace them all. If one was worn due to age then they're all in the same condition usually. Also inspect the coil packs for blistering or heat damage.
Old Dec 8, 2017 | 08:58 PM
  #10523
I finally ordered the 350z passenger seat controls from CZP this week. Will be here on Monday.
Coz from CZP thought there was a good chance it would work.
Knowledge staff at CZP, highly recommend them if you are looking for parts.
Old Dec 10, 2017 | 03:08 AM
  #10524
ScraggleRock's Avatar
All of CZP staff is amazing. Not pumping them for no reason, it's just the truth. Always very very helpful and FAST with response times.
Old Dec 10, 2017 | 03:12 AM
  #10525
You replaced one spark plug? Lol
Ok, ok, replace all six, clean your TB, clean your MAF, and check for cracks in your rubber intake couplers. You'll be good as new and probably pick up 10hp.
Old Dec 18, 2017 | 02:17 PM
  #10526
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Can't seem to find a definitive answer to this...
Do the coupe front seats fit the sedan without modification? My driver's seat bottom cushion has a tear in it, seems like every other sedan I've seen being parted out has worse seats. If the coupe seats also fit, that opens up a lot more cars that may potentially have better seats.
Old Dec 18, 2017 | 04:30 PM
  #10527
cleric670's Avatar
BANNED!!!
No the brackets are different.
Old Dec 19, 2017 | 06:45 AM
  #10528
Blue Dream's Avatar
I drove ttrank's car solo
Not true for the fronts but I bet the back seats don't^^ The brackets are part of the seats so the whole assembly bolts to the floor with 4 bolts.
A lot of sedan owners have swapped coupe seats in the front, the wiring usually needs to be spliced to get all the functions to work but they bolt right on. I bought a set of coupe fronts with the intention of changing them on my car but they were in worse shape than I thought they were so I re-sold them.
Old Dec 19, 2017 | 07:29 AM
  #10529
350z seats are also direct fitment.
Old Dec 19, 2017 | 03:26 PM
  #10530
cleric670's Avatar
BANNED!!!
Well that's news to me, I thought the brackets we're different for the coupe and the front-rear spacing was different on the rear bolts.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
