Random Little Question Thread
Old Feb 19, 2020 | 05:50 PM
  #10606
NAKo 106's Avatar
1) use dipsticks oil level. Your engine shouldn’t be filled to the oil cap with oil.
2) noise is likely the abs system doing a self test. Happens on most cold start ups within first 100ft of driving.
Old Feb 19, 2020 | 08:27 PM
  #10607
Gemichi's Avatar
Base model G35
Ahh, got it. Just to make sure since I kept on doubting myself. But the noise also happens during a warm startup. Is that mean the ABS is going out?
Old Feb 19, 2020 | 10:52 PM
  #10608
G2B35AGN's Avatar
No, it does it every time you start the car and begin to drive away...warm or cold. Standard self-test. Nothing to worry about.
Old Feb 19, 2020 | 11:53 PM
  #10609
Gemichi's Avatar
Base model G35
glad its something normal. I am starting to notice so many noises a car make when I bought this G lol. Now I'm noticing there are issues with my family's car.
Old Feb 20, 2020 | 11:47 AM
  #10610
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The first time the vehicle hits 10mph after it's been started it does a self-test of the ABS system, that's exactly what you are hearing.
It's hard to "unhear" it once you know about it lol.
Old Feb 20, 2020 | 03:07 PM
  #10611
Gemichi's Avatar
Base model G35
Interesting though how the Infiniti suppose to be a luxury car, is making more noises than the corolla (Matrix) lol. Of course it is still much nicer than the corolla.
Old Feb 22, 2020 | 09:13 PM
  #10612
baicep's Avatar
blackness
Today I bled my clutch and was struggling because there wasn't pressure on the pedal for it to come up. Only till I started playing with the slave cylinder I finally got it to have full pressure through the pedal on the way up. I exam the slave cylinder with valve close to see which way goes where when you press the pedal down. Pressing down the pedal, the slave fork or piston whatever moves out away, and pedal coming up it moves back down. So I did bleed procedure, crack open bleeder valve, told buddy press down and hold, I close bleeder valve, told buddy to come up on pedal, and then I helped assist the slave cylinder by pushing it down a little since I notice there wasn't a lot of travel going on with the fork (or piston whatever lol). Only then I finally got pressure on my pedal so I stopped. Why is that? Do I need to grease up the slave cylinder in the boot or something? Is my cylinder going bad? This isn't an old cylinder it was replaced already before probably no more than 30k miles.
Old Feb 23, 2020 | 10:10 AM
  #10613
cleric670's Avatar
BANNED!!!
The clutch fork will push the slave cylinder back in because of the clutch pressure plate. Remove the slave cylinder and push on the clutch fork with your hand, it should be VERY stiff.
Are you saying that the clutch fork isn't pushing the slave cylinder piston back in? Or is that functioning properly but the clutch pedal just won't lift?
I would order the rebuild kit for the CMC and CSC and just rebuild them both, it's less than $50 worth of parts to rebuild them both with OEM components.
CMC rebuild kit
https://www.z1motorsports.com/clutch...it-p-9662.html
CSC rebuild kit
https://www.z1motorsports.com/clutch-slave-cylinder/nissan/oem-clutch-slave-cylinder-rebuild-kit-vq35de-p-9651.html
Old Feb 23, 2020 | 01:13 PM
  #10614
baicep's Avatar
blackness
CMC rebuild kit
CSC rebuild kit
After rewatching bleeding videos I think I know what I did wrong. I didn’t build pressure before releasing the bleeder screw. I never told my bud to pump 5x and hold before I cracked the valve open. I only told him to press down and hold. I read some where on the forums that the system doesn't build pressure like the brakes do. Thing is my clutch feels good right now though. Once I saw the fork traveling full distance I didn’t want to bleed anymore lol.
Old Feb 23, 2020 | 10:30 PM
  #10615
cleric670's Avatar
BANNED!!!
Correct it doesn't BUILD pressure like the brakes do but it's still a hydraulic system. Basically the only difference is you just pump the clutch once whereas the brakes you pump it a few times.
It certainly wouldn't hurt to push the pedal a few times but it's not necessary, it won't build and store pressure.
How certain are you that your buddy knew what he was doing and wasn't accidentally letting off the clutch before you tightened the bleed screw? Are you sure the reservoir never went empty?
If you are sure it was done properly then you should just rebuild both CMC and CSC. Typically they are replaced/rebuilt at the same time anyways because they wear out at nearly the exact same rate.
The rebuild is SUPER easy btw, no way I would buy an aftermarket one and I wouldn't even get an OEM unless the wrong fluid was used and pitted out the cylinder wall.
Old Apr 26, 2020 | 08:49 PM
  #10616
EZChase's Avatar
G35X Premium Sedan
Does anyone know why my premium sedan would not have reclining rear seats? Its really bugging me!
Old Apr 26, 2020 | 10:50 PM
  #10617
cleric670's Avatar
BANNED!!!
2005-2006 had an option for rear buckets that deleted the reclining rear seat from the premium package.
Or you don't actually have the premium A package. Does your vehicle have dual zone climate control?
Old Apr 26, 2020 | 10:55 PM
  #10618
EZChase's Avatar
G35X Premium Sedan
yes it has everything except nav and rear reclining seats. So the bucket seats are another option instead of the reclining ones?
Old May 1, 2020 | 09:59 PM
  #10619
cannavis's Avatar
sport
small question will the 2007 headlight assembly fit in a 2003? i want the projectors. will they fit?
Old May 1, 2020 | 10:34 PM
  #10620
cleric670's Avatar
BANNED!!!
Nope, completely different platform. V35 is 2003-2006 sedan, V36 is 2007+
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
