High pitch noise coming from engine....Anyone?
Old Oct 24, 2010 | 07:30 PM
t3_123's Avatar
Thank you i need to change my belts.
Old Oct 26, 2010 | 10:19 PM
manny16030's Avatar
hey everyone just to update yall on what the solution was. It turned out to be a bad seal with the plenum gasket. I suspected it but didnt think it was that because only a few weeks ago i had the gasket replaced. on the good side i didnt get charged anything cuz they did a bad job. Glad they owned up to it.
Old Apr 8, 2012 | 12:30 PM
danerikcom's Avatar
Originally Posted by Playa24_7
Getting my timing chain tensioner replaced on Monday, as well as all the other tensioners, guides and chains since it will already be open haha. Fack! 12 hours labour, not cool. It is very rare though. The dealer said they sell like 2 kits a year lol.
How much are you being quoted for the job?
Old Feb 22, 2019 | 05:32 PM
smallguy2020's Avatar
g35 coupe
hey guys I just bought an 06 g35 coupe the guy I bought it from mentioned the car overheats after driving for 15 minutes. Also there's a High pitch noise from the right side of the engine bay sound like the belt or possibly the WATER PUMP? any suggestions?
Old Feb 22, 2019 | 05:38 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Water pump is driven off the timing chain, pressure test your coolant system for leaks, pressure test your cap as well. Check between your radiator for debris accumulated between it.and the condenser. Test your thermostat for opening in 180° water. If all else passes change out the radiator. Check that BOTH fans spin at both high and low speed (high speed comes on when you push then AC button so easy to test). If you have a 2003 with a mechanically driven passenger fan test the fan clutch.
If all else passes swap out the radiator. Good chance you'll find the issue long before that.
Do research on how to bleed the coolant system.
Old Feb 22, 2019 | 05:41 PM
g35 coupe
Im having the same problem with my g35 as soon as I start it up it has a loud whistle almost like a kettle its terrible.
Old Feb 22, 2019 | 05:42 PM
cleric670's Avatar
BANNED!!!
Loose drive belt maybe?
Old Feb 22, 2019 | 08:57 PM
cswlightning's Avatar
Smallguy spray water on your drive belt when that happens, if the sound goes away you probably just need to tighten your belt or replace a cheap pulley.
rezendvous420
May 31, 2020 01:26 PM
Wayne9011
Aug 17, 2015 01:24 AM
ScraggleRock
Aug 11, 2015 10:16 PM
atk08
Jul 30, 2015 03:12 PM
Wayne9011
Jul 27, 2015 11:25 AM
