What ECU do I have
Old 01-19-2011, 09:57 PM
kyemaul's Avatar
I feel like selling again!!!!
  #47
Old 01-19-2011, 11:01 PM
kyemaul's Avatar
If I go F.I. how will I tune that ? I heard some of the turbo kits come with tuning or something like that
  #48
Old 01-19-2011, 11:02 PM
NFSP G35's Avatar
? = 2B || !2B
^Piggyback or standalone.
  #49
Old 01-19-2011, 11:05 PM
kyemaul's Avatar
Does the kits come with that I heard the standalone are alot of money
  #50
Old 01-21-2011, 04:28 PM
kyemaul's Avatar
I went to a uprev dealer today (Performance MotorSports) theexperience.com if you guys in NY want to check them out. Thoes guys checked my ecu to see if it was able to tune........Yes it its they just need to dump the ecu file because they dont have the rom for my particular ecu. As long as it dumps the ecu can be tune by uprev!!! If im explaining right but bottom line my september 02' production 2003 G35 sedan can be tuned..
  #51
Old 01-21-2011, 05:17 PM
DaveB's Avatar
Originally Posted by kyemaul
Do you think that plus the blitz throttle controller would help the throttle responses.!
It will definitely help with throttle response and I'm looking into getting the Blitz throttle controller, but my fear is that Blitz isn't aware that the 03 5AT sedan has a 2.5 V pedal vs the 5V pedal used in all the other VQ cars and it may not work right on the 03 5AT sedan. The connector is exactly the same between the pedals. Blitz lists the throttle controller as working for ALL 03-06 G35s. The infamous SprintBooster doesn't differiate between the years either, just transmission. I'm a bit worried.
I too am getting a bit fed up with the limitations of the 03 5AT sedans and TS pulling the plug on tuning is really upsetting. I'm very close to pulling the trigger on a 04 G coupe 6MT or maybe a 11 WRX base.
  #52
Old 01-21-2011, 05:22 PM
kyemaul's Avatar
What's the production date on your G
  #53
Old 01-21-2011, 11:29 PM
DaveB's Avatar
what's the production date on your g
7/02
  #54
Old 01-22-2011, 12:03 AM
kyemaul's Avatar
7/02
I went to a uprev dealer he said he can tune my car!!! Mine is 09/02 but accourding to the factory manual for our cars my car by vin# has the old ecu!!!! Is your A/T????
  #55
Old 01-22-2011, 12:54 AM
NFSP G35's Avatar
? = 2B || !2B
^Yes. Dave's is AT (his sig)
I'm guessing this shop is tuning the ECU in the same manner as TS did
If so, maybe they can setup a program where early ecus can be mailed in, reflashed, and returned, like TS.
  #56
Old 01-22-2011, 02:27 AM
srv2nv's Avatar
If they're tuning old style ECU's, let us know, and let them know theres people interested.
I'm considering an Emanage, but if theres a company doing reflashes, I'm in...
  #57
Old 01-22-2011, 09:45 AM
kyemaul's Avatar
I don't think there doing it the way TS did it. There doing a Uprev reflash they said I have the new ecu, but the factory service manual said I had the old one. Even when I called uprev in texas directly, they said my ecu isn't compatible with there product and they have no intentions on any tunes for the older ecu's. Then when I went to a tuning shop that does uprev tuning they plugged it up to the ecu and started dumping my ecu so it can be tuned. I think you should go to uprev or a dealer and have them try and tell you exactly if you can or cannot. I heard a lot of feed back on this subject I appreciate all you guy input.
  #58
Old 01-22-2011, 12:57 PM
DaveB's Avatar
I sincerely hope the best for you, but be prepared for it not to work. I believe someone had tested a Hypertech programmer on their 03 5AT sedan and everything appeared to work fine (ie the programmer talking with the ECU), but when it came time to upload the program, the ECU said NO WAY.
06g35
02-14-2022 05:59 AM
esotericrider
V36 General Tech Questions
03-04-2019 07:53 PM
Mad A
Not G35 Related
12-08-2015 01:45 PM
MThawkins86
10-24-2015 02:07 AM
G35VSHNG37
09-10-2015 01:54 PM
Quick Reply: What ECU do I have
