VDC & SLIP light! Stalling! Help!
Old Jul 1, 2011 | 08:56 PM
ShagZvil1's Avatar
hello g35drivers! i have a problem, i have a 03 sedan with around 89xxx miles. engine is cherry. Ive had this car for the past 4 months, i bought it at a tow yard. anyways, what the car does is everytime i start it is there are no lights except service engine soon and airbag light, when i put it in drive and if i tap the gas too hard the car sort of stalls and slows down, as if the differentials are locking up and i press the gas and it goes nowhere, its only until the slip and vdc lights pop up, it drives fine. this only happens when i first start up the car and drive away. so my routine is to put it in drive and let it roll till the lights turn on, then its fine. if i push the gas lightly its fine. only when i push the gas a little bit more is when she stalls out, there is a loud rubbing sound is from the rear. It is only after the slip/vdc light come on the car accelerates fine. i had a mechanic check out my diff fluid and everythings fine. he says hes not sure what the problem is. I would like to know anyone with a similar problem with a solution or any opinions. Thank you
Old Jul 2, 2011 | 06:06 AM
butkiss1's Avatar
push the VDC button 1st then see if it stalls , Any time my VDC is off ,and I get wheel spin the ECU shuts power for about a second,
Secondly have the code read for your CEL .
Old Jul 3, 2011 | 04:05 PM
ShagZvil1's Avatar
will do thanks man
Old Jul 13, 2011 | 10:19 PM
ShagZvil1's Avatar
yeah pushed the vdc button to off. i take off and its perfect. the slip light still comes on but doesnt stall anymore. i dont mind pushin the button when leavin. but great solution. thanks man.
Old Jul 13, 2011 | 10:25 PM
butkiss1's Avatar
Another satisfied customer
Old Jul 31, 2011 | 11:48 PM
dul311's Avatar
i have this same issue except my car stalls while driving and the check engine light comes on so does the SLIP. These things started happening after I installed a Ztube pipe. It's really weird. Today it stalled while driving on the highway. VERY DANGEROUS.
I plan to go to Autozone or Advanced Auto to borrow their scanner.
Any help would be appreciated.
THanks,
Dul311
Old Aug 1, 2011 | 01:37 AM
butkiss1's Avatar
THanks,
Dul311
If the ECU detects wheel spin it will cut power for about 1.5 seconds.
Old Aug 1, 2011 | 06:30 AM
Mustang5L5's Avatar
THanks,
Dul311
Get the engine code and post it up.
Old Aug 5, 2011 | 06:05 PM
Theory_EK's Avatar
Its probably p0345 and its a camshaft sensor.
Old Aug 5, 2011 | 08:29 PM
G35nNJ's Avatar
What he ^ said...I had the same problem and that's what is was camshaft sensor...changed both
Old Oct 30, 2011 | 03:41 PM
butkiss1's Avatar
Originally Posted by PerryIsA1
I have an 04" sedan and i started getting this issue when i replaced the rack & pinion. is there anyway to fix this? id like to have my traction control back since the rain is coming and im rear wheel drive only. haha
another way to get the slip to show up without driving and waiting for it to catch is by turning your steering wheel all the way left. when i do that with my car, slip and vdc lights turn on.
That doesn't sound right.U might wanna get that checked out.
Old Oct 30, 2011 | 06:07 PM
DaveNYC's Avatar
I had a similar issue it could be either camshaft or crankshaft sensor. In my case it was crankshaft since it ripped on me being low lol.
Old Oct 30, 2011 | 10:06 PM
GOAT35's Avatar
If your interior lights are not working that's a BCM error you need a new computer about $400+ from the stealership!
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
JermaineSanders
Aug 18, 2015 08:57 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
