my pass side front wheel bearing going bad?
Old Nov 11, 2011 | 03:12 PM
cmex's Avatar
i hear airplane like sound from right side front over 40mph..... wheel bearing? or?
Old Nov 11, 2011 | 08:16 PM
jayflyxx's Avatar
yes. I have been made aware that G35 go through wheel bearings... LoL
Old Nov 11, 2011 | 09:04 PM
Project's Avatar
Yup. From the sounds of it. You can jack that wheel up and shake it in and out it shouldnt have any play at all.
Old Nov 12, 2011 | 12:32 AM
jeggo's Avatar
Pretty sure it's the bearing. I ordered mine at eBay for $150 shipped.
Old Nov 12, 2011 | 06:27 AM
Blue Dream's Avatar
I drove ttrank's car solo
Could also be a cupped/feathered tire, they sound a lot like a bad bearing.
Old Nov 12, 2011 | 12:53 PM
pulsar1's Avatar
The joys of G35 ownership. "Whats this noise?" Wheel bearing, the answer is always wheel bearing.
Old Nov 12, 2011 | 01:01 PM
MikeDG's Avatar
+1. Might also have your alignment checked. If your toe is out of spec it will accelerate the tire wear and can make a similar noise.
Old Nov 12, 2011 | 08:54 PM
G35xChicago's Avatar
If your tires check out fine, def the bearing. Ive had to replace all of mine.
Old Nov 13, 2011 | 12:00 AM
Anton_Chigurh's Avatar
04 i am looking to get has 2 front bearings that are bad...very loud noise above 30 mph..also a little vibrating in wheel
Old Nov 14, 2011 | 08:56 AM
cmex's Avatar
thank you !!! def vibration in the wheel and my tires are ok,,, low on thred but OK,., alignment was done 4 months ago..... so that is not the issue,,, sound only comes out 35+mph
Old Nov 14, 2011 | 08:57 AM
cmex's Avatar
should i replace 2 fronts at the same time? replace the other when it goes bad?
Old Nov 14, 2011 | 10:57 AM
High_Boost's Avatar
when I had that noise I jacked up my car and I couldnt get any movement out of the bearing, so I changed the tires instead..
the noise was still there, so I changed the bearings.. quiet as can be, even though there was no play at all
I would do both of them.. the other one probably isnt far behind, plus it is a good idea to get your alignment done afterwords, and it is better to only pay for that once
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
R350k5
Oct 1, 2015 08:41 PM
rping
Jul 26, 2015 09:53 PM
itschuckster
Jul 25, 2015 08:07 AM
