Sudden loss of power
Old Dec 31, 2011 | 03:09 PM
LAW 11's Avatar
Car was running fine then suddenly lost power. you can ease on the excelerator and you can get up speed to get around but if you push hard down on the pedal its starts to take off then bogs down and the does this pulsing action and then finally stalls to idle. Thoughts? Had a bmw do this and it was the exhaust converter... but could it be fuel starvation? thanks GRT
Old Dec 31, 2011 | 07:33 PM
hyperwhite's Avatar
Any check engine light on? If no, Check for any loose hoses, electrical wires etc. If yes, plug in an OBD2 scanner and find out the error code here.
Old Dec 31, 2011 | 09:30 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Fuel pump?
Really, way too many things can cause this, so hopefully it'll throw a code and give you a hint where to start.
Old Jan 2, 2012 | 11:42 AM
LAW 11's Avatar
No codes...but what happened was that car went into LIMP MODE. some sensor picked up a spike that was not long enough to lock a code. car runs fine now a friend who is a specialist in the computers said that until it locks a code, you cant trace it...but he has seen alot of 3.5 engines do this once then not again ...at least for a long time then you will get a code...GRT
Old Jan 2, 2012 | 11:52 AM
pulsar1's Avatar
Mine did the same thing but I got a CEL turned out to be the MAF.
Old Jan 2, 2012 | 12:13 PM
LAW 11's Avatar
thanks will keep eye on that... will also check clamps to make sure no air leaks
Old Jan 2, 2012 | 04:31 PM
sonicii's Avatar
if it went into limp mode, there should be a code stored in the ECU history, even if it didn't trigger a CEL. You may need consult, or a datascan tool to find it though.
Old Jan 2, 2012 | 05:47 PM
pb35's Avatar
Same thing happened to mine years ago though I got a CEL. Turned out to be the throttle chamber.
Old Jan 2, 2012 | 11:34 PM
B T's Avatar
B T
lol, excelerator, cause our cars excel?
Old Jan 3, 2012 | 10:21 AM
BallerOnaBudget's Avatar
Check your throttle body! My buddy just had the same issue with his truck (yesterday) and we disconnected the negative battery terminal for about 5 minutes (just to reset the ECU) and he was able to get it home just fine and we ripped the throttle body out and cleaned the ever-living P!$$ out of it and he said not an issue yet...I've used this same method to cure the same problem on a few other cars!...hope it helps buddy!
Old Jan 3, 2012 | 02:26 PM
SedanFan's Avatar
Yeah my 2006 went into limp mode and it was throttle related as well.
Old Jan 3, 2012 | 02:48 PM
Kim@Forged's Avatar
Something similar happened with my car and it was a faulty alternator. It eventually got worse and worse and the car died. But like what everyone else said, there could be many different causes.
Old Feb 20, 2018 | 09:53 PM
Wocka87's Avatar
Exhaust leak
I have the exact same thing happening with my 2003 sedan. I know for a fact i have a good size exhaust leak. Possible that has something to do with it?
Old Jan 29, 2021 | 01:58 AM
Freeman's Avatar
2004 infiniti g35
Power loss
​​​​​​HI 👋 so how or what did you do to fix it I'm having same problem?
Jasper_
Jun 25, 2021 01:01 PM
Whittall54
Dec 11, 2020 04:29 PM
PeteG35s
May 8, 2017 11:13 AM
dmitriypopov
May 10, 2011 10:33 AM
sonsofliberty
Feb 14, 2010 07:38 PM
