Check Engine Light
Check Engine Light
Yesterday I took my air intake out of the engine bay so I could better reach lower parts on the engine while I was cleaning it. I had to unplug the air sensor but wasn't sure if I needed to unplug the negative on the battery also so I didn't. I have been driving around all day know problems and just started the car then the Check Engine Light came on. Is this something I can get rid of if I unplug the negative battery and then unplug and replug the air sensor? Need help please.
Had the code read this morning. It turns out that when I start my car the idle is way higher then normal. I noticed a couple times when I turn on the car it does goes all the way up to 2k and then drops down. I did clean out the carb when cleaning out my engine so maybe thats the issue. The mechanic said just give it a few days and let the car reteach itself.
If you did, then your idle relearn is fked and need to be reset.
Search the forum for the procedure... (Its a tad complicated and takes a few tries to perfect)
But try the negative battery cable first. Take it out for an hour, reconnect and wait to see if CEL comes back on.
I unplugged the wire connected in between my Z tube and air filter. I then disconnected the whole thing with the closest clamp next to the plenum block. I opened the carb and sprayed some carb cleaner inside and wiped it out. After I had the code erased I have not had the check engine light come back on but when I start the car in the morning when the car is cold it still goes up to 2k, but other then that it is normal start. I forgot to get the code sorry. Should I let it sit another day or so and see and see what happens? Or should I unplug the negative and let it sit. If I do that will I need to unplug the wire connected to the air intake again? If you can give me a search word to look up the process to fix this or link I will check it out. Thanks everyone for your help! I must say this has been the most helpful forum I have ever used. Everyone is so cool here!
Here are the reset procedures. I would think you would need to do the idle air relearning whether or not you disconnect the battery.
https://g35driver.com/forums/4141497-post14.html
