Steering Problems 03-06 g35 sedan
Old Apr 4, 2012 | 10:11 PM
bkellz08's Avatar
I need a little help with my vehicle ... 03 g35 sedan.... Just had both Lower control arms and spindle ball joints replaced...Now when i turn it pulls to whichever side i turn to. and also the steering is more stiff and responsive. But the main issue is that pulling when i turn a tight corner... I can let the steering wheel go while turning and ill be doing perfect circles... The mechanics act as if they have no clue of whats going on. But my car wasn't doing it before the install? They think the ball joints need time to adjust, and they don't think an alignment will solve the problem. Some type of help would be appreciated... Thanx Guys...
Old Apr 4, 2012 | 11:24 PM
AARONHL's Avatar
I think an alignment will help, is your steering rack leaking?
Old Apr 5, 2012 | 09:30 AM
bkellz08's Avatar
No sir
No leeks at all... I watched to whole procedure in depth... Didnt seem like they screwed up in any way? And it only does it when im turning really tight... normal turns and going straight are ok... Firm? But ok... Its like it has a mind of its own or something when im turning tight corners. And i'll def mention an alignment. Even though they think for some reason it might not work.
Old Apr 5, 2012 | 10:19 AM
AARONHL's Avatar
I've noticed when I change some suspension parts (changing the alignment), the steering wheel doesn't like to return back to center without my help after turns.
I've never heard of ball joints needed "time to adjust". I would also check the outer tie rods. Do you notice any clunking while driving the car?
Old Apr 5, 2012 | 08:15 PM
bkellz08's Avatar
Yes some clunking, But ive had mechanics confirm that it's caused my the compression rod's ball joints and bushings. These were the same problems i had before the install though... So there's gotta be something else to it?
Old Apr 5, 2012 | 08:46 PM
AARONHL's Avatar
Well if the compression rod ball joints are busted, your caster alignment could be different on each side. That might be causing the turning issues. I replaced a compression rod yesterday because the ball joint was busted (making a lot of noise) and it is a totally different car now.
Old Apr 5, 2012 | 08:53 PM
bkellz08's Avatar
I do understand what your saying. But in that case? why wasn't this the problem before the install, because the compression rods ball joints and bushing's never changed.
Old Apr 5, 2012 | 09:05 PM
Hotdawwgman's Avatar
My steering rack was leaking but I never had a puddle. It was just building up dirt and gunk. So much better feel once it was replaced 2 weeks ago...
Old Apr 6, 2012 | 01:37 AM
AARONHL's Avatar
If the problem started after the recent replacements, I think you should get an alignment. If your mechanic doesn't know what's wrong then take it somewhere else!
Old Apr 6, 2012 | 12:32 PM
cmurphy84's Avatar
At full lock and while idling in 1st gear, my car will to the same. Give it some gas and it straightens itself out. I don't see it as a problem. At least I can feel the road now. My old Chevy Silverado might as well have been driving with a joystick. Absolutely NO feel at all and it was stupid sloppy. The G35 steering reminds me a lot of my '92 Accord. That's a good thing.
Old Apr 8, 2012 | 01:13 AM
bkellz08's Avatar
I've had 2 other places check it out, and they both said either one or both of the castle nuts on top of the ball joints were either torqued too tight? OR the ball joints i purchased were already bad... i was like WTF !!!
Old Apr 8, 2012 | 06:38 PM
AARONHL's Avatar
I don't think it's possible to over tighten out ball joints because there is a conical spacer on top.
Old Mar 7, 2020 | 06:20 PM
DumpsterJedi's Avatar
Buuuuuump
I this thread is super old, but Im in the same exact situation, did you ever figure it out? I just replaced both lower ball joints (by taking out the entire steering knuckle though) and now it pulls into the turn at low speeds but drives perfectly at high speeds.
Old Mar 7, 2020 | 08:30 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Replied to your other two threads, no need to bump.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
Karnicle
Jul 23, 2015 05:08 AM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
