sputtering around 4k
Old Sep 7, 2012 | 07:42 PM
3000vr4tt's Avatar
i just picked up an 05 g35x auto and i noticed when im in 3rd gear and go wot at about 4krpm it sputters for a sec then goes..anyone else have this problem?
Old Sep 11, 2012 | 11:01 PM
bizz518's Avatar
Are you using premium gas?
Old Sep 12, 2012 | 01:14 AM
ad4m510's Avatar
check ur spark plugs
Old Sep 12, 2012 | 03:38 PM
Gold2006G's Avatar
same thing happenning to my 06 5at. in any gear in manual mode it hesitates from about 3600 to 3800 rpms then pulls hard. know my spark plugs are original and need changing though, it has 104,000 miles on it. also the air filter is about to get replaced with k and n. I think with new plugs and a new filter it should be good. After that I would get the throttle body cleaned......
Posted from G35driver.com App for Android
Old Sep 12, 2012 | 05:30 PM
3000vr4tt's Avatar
ya 93 gas and ill def check the plugs next chance i get.. anyone recommend a specific plug for these cars?
Old Mar 16, 2013 | 10:54 AM
3000vr4tt's Avatar
ok guys i changed the plugs with ngks...did a lucas fuel treatment...car ran good and mpg went up no hesitation..about a few days later went back to low mpg and i still get the sputtering around 4-4.5k i noticed the stock filter was dirty so i put in a z1 hi flow filter with the ztube and still sputtering..i also ran another fuel injector cleaner and no difference
Old Mar 16, 2013 | 12:11 PM
cyphen's Avatar
Dejavu!
Go look at my thread. My passenger side cat is clogged causing the same issue. I am in the process of attempting to acquire some new high flow cats to replace them.
Also, go get some CRC MAF sensor cleaner and take the MAF sensor out and clean it.
Heres the link to my thread about this.
https://g35driver.com/forums/g35-sed...ark-plugs.html
Old Mar 16, 2013 | 04:51 PM
srv2nv's Avatar
G35 Sport
Any codes?
Spark plugs would be my first guess, although my dads Dodge Ram was doing the same thing a year ago and it turned out to be a bad O2 sensor.
See if you can jack up the front end and pull them out to see if they're still good.
Old Mar 25, 2013 | 03:28 PM
3000vr4tt's Avatar
Originally Posted by srv2nv
Any codes?
i changed plugs and it was fine for a day or 2..i mean it sputters at 4k then after that it goes back to normal an hauls ***
Old Mar 25, 2013 | 06:41 PM
yosip1115's Avatar
Is it stock?
Old Mar 27, 2013 | 07:57 PM
ericdeyoung19's Avatar
I actually have the same problem - it seems like right around that 3.8k-4k mark, there is a little loss of power, then it goes back to pulling hard. Interested in suggestions!
Old Mar 28, 2013 | 05:36 PM
3000vr4tt's Avatar
Originally Posted by yosip1115
Is it stock?
ya bone stock so i put an intake after still problem
Old Mar 28, 2013 | 11:49 PM
yosip1115's Avatar
I had this issue with a few bolt on modifications, and a catback. It gave me a really good excuse to splurge and replace my catalytic converters with AAM. It's a good idea to replace the y pipe while you do this if your interested... But my issue was either my o2 sensors or the stock cats got clogged up, I'll never know. But regardless it's a good idea
To do both because you won't get the stock o2's out without ruining the threads.
Old Jun 24, 2013 | 04:11 PM
3000vr4tt's Avatar
so you fixed this issue by changing the cat?...and way to test the cats out?
OMG35S
V36 Engine, Exhaust, Drivetrain & FI
Feb 13, 2026 07:32 PM
06gtfanatic
Aug 31, 2015 03:19 PM
pricojorge
Apr 10, 2011 01:12 AM
RamboRami
11
Aug 7, 2003 09:19 PM
