Just hit 200k!!
Old Jan 20, 2016 | 02:20 PM
  #46
TheTick's Avatar
Transmission just started to slip and clunk into gear. Now a bit over 280k miles. Can't remember the code, but it's a solenoid which isn't sold separate from the valve body. So decided to pay a bit more for a used tranny with 67k miles and 5 year warranty for $1500.
Waiting for it to deliver to my mechanic. This would be the most expensive repair so far. At 280k, can't complain at all. Up to now, the car has been amazing. Nothing but standard wear and tear stuff at high mileage.
Old Jan 20, 2016 | 03:24 PM
  #47
Mustang5L5's Avatar
Good to hear.
I'm at 167K. Seems so little compared to yours.
What were you doing for trans maintainence up to the failure?
Old Jan 20, 2016 | 03:56 PM
  #48
TheTick's Avatar
Originally Posted by Mustang5L5
Good to hear.
I did the drain and fill myself every 30K, but I would often do an extra drain and fill with an oil change just to be ****. However for that last couple years, I pretty much stuck to 30K intervals. The last couple times I noticed that the fluid wasn't as red as usual. Makes me think that I should have kept it at 20k intervals. Transmission was flawless until this one component failed.
Old Feb 25, 2016 | 09:58 AM
  #49
G35fromPA's Avatar
Great stuff. I'm only at 57K on my '04 Coupe, but aside from a few minor issues & the occasional squeak/rattle, this car has been extremely solid over almost 11.5 years of ownership. I change the oil every 6-8 months or so w/synthetic (usually ends up only about 3K miles), have replaced the drive belts twice, have changed gear fluid twice, and the diff and clutch fluid once each. I tend to flush the brake fluid every 3 years or so. Clutch is still running strong @57K.
My only real issues over the years have all been minor:
- Axle click (fixed under warranty)
- Fuel filler neck and fuel level sensor replacement (warranty)
- Drivers side window motor (warranty)
- Driver seat rail replacement (warranty)
- Noisy fuel pressure regulator replaced
- Compression rod bushings replaced twice (both under warranty)
Old Feb 26, 2016 | 11:38 AM
  #50
IllaNoizeTV's Avatar
Originally Posted by TheTick
This has been the best car I have ever owned! I do all the fluid changes myself and meticulously change the oil every 10k with mobile 1 and larger maxima filter. Tranny drain and fill every 30k with J-matic. Other than than the belts needing replacement and airbag recall, I have had ZERO issues, I top off a quart of oil every 3500 miles and the motor runs like new.
Due for another fluid change on diff and radiator which was very easy to do the first time. Couldn't be happier with this car!
This is awesome! I'm very happy with my new to me G35. This platform is very solid, reliable, and powerful. Props on the mileage. I plan to keep this car for a very long time as well so maybe someday I'll see that number!
Old Mar 14, 2016 | 02:10 AM
  #51
2slickg35's Avatar
Wow, you're doing pretty well for 280K miles!
My old G35 that I gave to my brother had 194K miles before it was rear-ended(total loss) by an inattentive driver. Car still had a lot of life left.
Old Mar 14, 2016 | 05:43 AM
  #52
telcoman's Avatar
Veteran: Army
Good to hear.
Saying good by to my 2006 G35 6 speed manual
Rather than spend a few thousand on brakes, drivers headlight ballast, and a leaking differential seal, I decided a new G37S was the way to go.
No more mileage bragging rights for me.
Telcoman
Old Mar 14, 2016 | 08:29 AM
  #53
Mustang5L5's Avatar
Telcoman
I'm waiting for a slew of issues to force my hand that way as well.
So far, can't justify it...yet....
Old Mar 17, 2016 | 09:37 AM
  #54
jbarnett250's Avatar
I rolled over 200k last night. The car is running pretty good. I had to fix my 3rd brake light to pass inspection in January and I've got an intermittent evap code to deal with. But no major mechanical problems. I changed my valve cover gaskets and oil cooler gaskets a while back and seem to have the occasional burning oil smell in the cabin again so must have developed another leak. Probably didn't get the VC sealed well....
Old Apr 1, 2016 | 01:06 PM
  #55
TheTick's Avatar
My mechanic swapped out the tranny with no issues. Runs perfect now. The rear struts were shot so I had them replaced while it was on the rack.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
KruZZe
Feb 27, 2023 05:04 PM
06g35
Feb 14, 2022 05:59 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
G2B35AGN
Sep 25, 2015 10:49 PM
