NEED HELP WITH MY G35x!
Old 11-25-2015, 01:04 PM
2005 G35x's Avatar
So I know the sedan models already dont have that many upgrades but the X has a lot less... I'm trying to find Headers that are powerful and gain a little extra HP. I'm also looking for good lowering springs. Can anyone help me out?
Thanks!!
Old 11-25-2015, 01:37 PM
CV35Driver's Avatar
Thanks!!
Hey There,
Long Tube Headers may not fit. All other regular headers should fit no problem. As far as springs, all the springs from the 350z or G35 03-07 will fit with no problem. The question is the amount they lower. Take a look into the calling all Xs thread if you need more info on that to find the exact setup you need.
-Ali
Old 11-25-2015, 02:04 PM
2005 G35x's Avatar
When I look at all the headers though it says they are for the coupe. will they fit on the sedan or try to find ones for the sedan?
Old 11-25-2015, 02:06 PM
CV35Driver's Avatar
They should fit with no issues. Just confirm with multiple sellers just in case. Megan Racing Headers will fit the coupe and sedan no problem.
Old 11-25-2015, 02:08 PM
2005 G35x's Avatar
Alright thank you! Also I have a 3" tip Manzo catback exhaust and am trying to get a full exhaust (Why im asking for headers) What else would I have to get?
Old 11-25-2015, 02:15 PM
CV35Driver's Avatar
In all honesty, don't get the Manzo and get a proven setup for performance. The Manzo is a cheap eBay knockoff that you won't gain power on. You would need to look into the inlet and outlet and go bigger than OEM size to see some gains. You would also need HFCs or TestPipes to remove the restrictive cats.
Old 11-25-2015, 02:23 PM
2005 G35x's Avatar
http://www.manzousa.com/index.php/pr...k-exhaust.html
This is the exhaust I have and your saying its not good? Ive had a good time with it nothing bad at all. But what exhaust set up do you think would be a good one? I would do test pipes but the whole emissions testing would be a bitch.
Old 11-25-2015, 02:30 PM
CV35Driver's Avatar
It's okay. Looks like a copy of the TopSpeed Pro1 Exhaust actually which is the one I have now.(I'm not really performance oriented). If you want to maximize gains, I would go with a HFC setup and a exhaust like the Tanabe, Megan Racing is okay, Stillen is pretty good, and a few others as well such as the HKS axleback. There are a few options out there for gains. Black Friday deals are to be had as well. Headers are a pain to install as well but if you wanted a full exhaust, it makes a difference.
Old 11-25-2015, 02:37 PM
2005 G35x's Avatar
alright. also my engine is about to give out. it has almost 114,000 on it and i want to get a new one. Do you know who makes great new VQ35 engines?
Old 11-25-2015, 02:39 PM
CV35Driver's Avatar
There are a few places out there but be mindful as you have an X, you would need to do work to the new engine to make it fix into the X. Although the cost associated with a reman engine is pretty high. You could buy a built shortblock in some cases for the same amount.
Old 11-25-2015, 03:00 PM
2005 G35x's Avatar
http://www.carmonkeys.com/2005-INFIN...Years-Warranty
Would this work? Since you said X is gonna be tricky then what about this engine. its AWD
Old 11-25-2015, 03:21 PM
CV35Driver's Avatar
Nah, doesn't list mileage or detail the exact condition of the engine. The problem is with installation. You don't want to install an engine to find out its billowing smoke out or low on compression. The X needs a few things swapped between the old and new motor. Not too hard. I mean for 2800+Install, I rather rebuild what you have and save money in the long run.
Old 11-25-2015, 03:29 PM
2005 G35x's Avatar
What are the most popular things to swap out on an engine rebuild?
Old 11-27-2015, 05:42 PM
TurTLe*'s Avatar
What makes you think its about to give out at 114k. That isn't much as many DE motors have proven solid in the 200-250k ranges.
I would strongly suggest you forget the headers and look into doing something with the factory cats.
Old 11-27-2015, 05:55 PM
2005 G35x's Avatar
Well every month something go wrong with the engine and then j have to bring it in to get fixed. And my exhaust already changed out the factory cats
Quick Reply: NEED HELP WITH MY G35x!
