Crack on Area around Power Steering
Old Dec 4, 2015 | 12:29 PM
CV35Driver's Avatar
Hey Guys, I need some help,
2004 G35X.
I was driving and a rock flew on to the road(construction) and went under my car.
I drove the car safely home and spotted this the picture attached below.
Any help would be appreciated on this.
Old Dec 4, 2015 | 04:10 PM
telcoman's Avatar
Veteran: Army
2004 G35X.
Take it to a muffler shop and get an estimate
Telcoman
Old Dec 4, 2015 | 06:53 PM
saywat?'s Avatar
^wats with posting wat gas u use? u proud of using 87 octane or something?
Old Dec 4, 2015 | 06:55 PM
JOKER's Avatar
CLUB MODERATOR
what exactly cracked? hard to tell on the pic.
Old Dec 4, 2015 | 06:58 PM
CV35Driver's Avatar
Unhappy
Sorry for the bad picture.
I figured it out. I cracked the engine cradle/subframe. The piece that holds the engine mounts and the power steering rack to the frame.
Due to the X having different components. I am sourcing a used subframe for me to use.
My steering is loose and to center it, it is turned to the right. Will have to look into what may be causing this as well.
Old Dec 4, 2015 | 10:35 PM
DeafBringer's Avatar
That's a pretty gnarly crack! This is what's causing your steering to be loose and off center as well.
Old Dec 7, 2015 | 08:21 AM
Mustang5L5's Avatar
That's a pretty major crack. How big was this rock? Had to be a considerable size to cause that
Old Dec 7, 2015 | 03:29 PM
CV35Driver's Avatar
Red face Some Updates:
It was a decent sized rock. There was construction on the side of the road so I drive careful always. The rock from the pile of the debris fell onto the road before I had a chance to react.
I had a G Specialist check into the damages and I am glad to say I got off a bit lucky but am very thankful. The aluminum splash cover from TBW saved my oil pan, engine, and suspension from being damaged. Highly recommend people take a look into his cover.
Only damages were the damaged KFrame/Engine Mount Cradle, power steering rack unit, and the two outer tie rods.
This pretty much set in stone for me to raise the car back up to prevent issues like this from happening again. Not stock height but a modest drop that will be able to drive around the city.
BradMD_96
May 8, 2016 09:40 PM
Jonjon93
Nov 30, 2015 08:39 PM
SlowG_Coupe
Nov 30, 2015 02:15 PM
ocxsa7141503
Nov 28, 2015 02:27 PM
