2003 g35 sedan over heating
Old Sep 8, 2019 | 07:22 PM
Eddie Javurek's Avatar
leather g35
My g35 is over heating don’t know why so here we go
first time it happened had a/c on and car sky rocket to over heating had car towed in they said thermostat they fixed it and burped the line car was good for awhile. Then couple weeks later with a/c on it over heated agine got it back to shop said nothings wrong... ok so took drive for 2weeks over heated agine with a/c on this time got it to my house let it cool off looked a few things, I just said screw it wont drive with a/c on worked for about a month then out of nowhere it over heated as soon as I got to work parked it came back to it when I was off started up and it was fine. Now I was driving down night way and it did it again my shop don’t know what it is they just write it off and I don’t wanna justart replacing a bunch of parts for no reason.... when it over heats the coolant comes out the over flow on revisor haven’t see. It come out any where els
some people say water pump, stuck shut thermostat,the bleeder tee cracked, clutch on fan, warped heads witch I hope not, head gasket but I don’t see any oil in antifreeze
please help gonna start pulling it apart tomorrow
Old Sep 15, 2019 | 09:19 AM
kelman81's Avatar
G35 Sedan Leather Base, Z1 Plenum Spacer, Z Tube (Currently sold to a friend)
No one can diagnose your issue as described from over the Internet. The shop you are taking it to is not doing you any good at this point. Someone, you or a more professional shop, needs to read the codes and systematically diagnose the issue. Also if it has overheated this much, you might have damaged the motor (like blown head gasket(s), warped heads, etc).
Old Sep 17, 2019 | 01:06 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
In the past, I've had issues with aftermarket thermostats failing, even when relatively new. You can find a new OEM thermostat on Amazon for not much more than aftermarket/autozone units, plus i think it includes the gasket.
Aside from that, can you verify the electric (or mechanical) fans are functioning? My electric fans on my 05 sedan turn on low ~203* and high at 207*. They should also turn on when you have the A/C running. Also, how old is the radiator? I changed one on my friends car that was full of corrosion from not running coolant/anti-freeze.
Old Sep 23, 2019 | 07:31 PM
leather g35
Over heating
Changed water pump changed two t-stats gave it a test for blowen head gasket it’s fine I took the heads off actually got them to a machine shop they said they where not wrapped changed head gasket any way. I was bleeding it for two days changed top rad hose new rad cap bottom hose stays cold
Old Sep 23, 2019 | 07:33 PM
leather g35
Over heating
Went to 3 diff shops and they did everything I already did I can kinda tell they didn’t know what els to do I’m about to take it to the steeler ship
Old Sep 25, 2019 | 02:20 AM
coffeysm's Avatar
Did you check your fans? How about the radiator to see if it's internally blocked?
Old Sep 26, 2019 | 10:40 PM
leather g35
Over heating
The clutch fan comes on when u first start it up and stays on and the electric fan I can tell is on when it starts over heating... so I’m pretty sure the running right and I took the bottom hose off put hose in rad cap and it came flowing out the bottom of radiator fine unless there’s clogged spots in it
cleverclaire
26
Apr 1, 2014 12:28 AM
speedvision1
Aug 1, 2012 09:20 PM
kvnmkz7x
Oct 31, 2011 05:08 PM
J3wman
Apr 10, 2011 05:01 PM
MJ-G35
Oct 15, 2010 04:19 AM
