Belts
Old Feb 28, 2020 | 06:00 AM
KevSil616's Avatar
Cream White / Standard
Belts
Hey guys recently purchased some new belts to replace the old ones which were worn out. I got the old ones off, but when I went to place the new ones they won't fit. I compared the old and new ones and they seem to be the same size. Is there something I am missing?
Old Feb 28, 2020 | 11:31 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like you cut the old belt off and never loosened the tensioners?
Or you have the belt routing incorrect.
Here's the tensioners.
Old Feb 28, 2020 | 12:57 PM
KevSil616's Avatar
Nope I loosened the tensioners and removed the belt without cutting it and followed the diagram of how they went, but it won't fit at all. I was able to put the old belts back on with no problem.
Old Feb 28, 2020 | 03:22 PM
cleric670's Avatar
BANNED!!!
And you're sure they're the same size as the existing belts? The only thing I can think is either the tensioner needs to be loosened more OR you don't have the belts into the grooves of all the pulleys and it's making them feel smaller than they actually are.
Old Feb 28, 2020 | 03:30 PM
KevSil616's Avatar
I put them side to side when I took the old ones off and they seemed to be the same size unless I'm missing it because they're a hair off. I loosened the tensioner more too and nothing, but like I said I was able to put the old ones back on with no problem. The best I can think of is the new ones were manufactured incorrectly and are slightly off. But not sure if this was normal
Old Feb 28, 2020 | 04:32 PM
cleric670's Avatar
BANNED!!!
What part number exactly for the new belts?
Old Feb 28, 2020 | 04:55 PM
cleric670's Avatar
BANNED!!!
Most people use Gates belts because they have a great reputation and aren't too expensive. Parts numbers are:
K060465RPM for the main drive belt
K040372RPM for the AC belt
Old Feb 28, 2020 | 04:56 PM
cleric670's Avatar
BANNED!!!
It's also possible you bought the belt for an HR motor which doesn't have one of the idler pulleys. A common mod on the G35 is to delete the top idler and use the HR belt, if your pulley configuration isn't EXACTLY like that picture I posted earlier and you have that top idler deleted then you will need the belt from the HR motor.
Old Mar 1, 2020 | 09:37 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
I take it that is to reduce parasitic drag?
Old Mar 2, 2020 | 11:30 AM
cleric670's Avatar
BANNED!!!
Yeah and to remove a useless idler that has a bearing that will fail someday.
EDIT: It's a real pain in the *** to get that thing off with the rev-up motor though, the castings for the cam adjusters sort of blocks it into place.
Old Mar 2, 2020 | 12:02 PM
KevSil616's Avatar
thanks I'll check these out
Old Mar 3, 2020 | 03:03 PM
kelman81's Avatar
G35 Sedan Leather Base, Z1 Plenum Spacer, Z Tube (Currently sold to a friend)
I have ordered Continental belts and pulleys for three different cars in the past few years, and the parts have been a crapshoot. About half of them were the correct size even though they cross referenced with their catalog.
I think Continental bought the Gatorback brand from Goodyear in the US.
cctaylor88
Mar 21, 2017 03:13 PM
G-owner
Jan 15, 2014 09:01 PM
JD_AND_DA_G_RIDE
DFW G35 Owners Club
Jun 8, 2011 05:37 PM
TwilightBLUES
Forced Induction
13
Nov 6, 2006 05:44 PM
