Headlight beam pattern?
Old Dec 6, 2022 | 11:30 AM
ASpec818's Avatar
Spent a couple hours cleaning my oxidized headlights. It was a night and day difference. I can finally see a beam pattern again. Prior to, there was minimal foreground and useable lighting.
But now I noticed the driver side has a hot spot higher than the beam pattern. Normally, there’s a gradual step up that lights signs for cars, but this hot spot seems higher and only on the driver side. Is this a normal pattern for an 05 sedan, or do I need to lower the driver side?
Old Dec 6, 2022 | 05:00 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Could be slightly out of alignment. Or one of the filaments has moved in the actual bulb. These are 16-19 year old bulbs now if they are original.
I replaced my OEM D2R bulbs with these: https://www.hidconcept.com/products/...ulbs-pack-of-2
Noticeable upgrade and whiter light. 4800K light vs 4300K OEM. They also have a version that is 5000K.
Old Dec 6, 2022 | 05:30 PM
ASpec818's Avatar
not original bulbs. the previous bulbs were 6k and getting pretty dim so i replaced them with 4300k morimotos. the beam pattern had the same hot spot on both bulbs.
are the philips noticeably brighter?
VladBostonRUS
Dec 18, 2008 09:15 PM
by15vc
Lighting
Jun 19, 2007 02:04 PM
Algy
May 15, 2007 07:47 PM
g35driver05
Oct 25, 2005 08:19 AM
