Strange sound when braking.....
Old Jun 13, 2005 | 11:16 AM
desertG's Avatar
When I am braking and making a turn at the same time, I hear a "creeking" sound coming from the front wheel areas. I notice it when I am slowing down to make a 90 degree turn into a driveway or parking lot. It only happens while braking. If I take the same turn without barking, I don't hear it.
Anyone experience this or know what I am talking about? I thought maybe the VDC was kicking in, but I don't see why it would at such a low speed.
Old Jun 13, 2005 | 12:19 PM
Birdhouse's Avatar
It's Lonely At The Bottom
Exclamation
It's your Brakes/Rotors. Get them checked out I am sure this is the problem. I've had the same thing happen to me.
Old Jun 13, 2005 | 12:22 PM
desertG's Avatar
If it was the brakes/rotors, then why would it happen only when turning and braking together?
Old Jun 13, 2005 | 12:39 PM
Birdhouse's Avatar
Lightbulb
I do not know the exact answer why. However, it happened to me and so I replaced the brakes and rotors at the same time.
First, when it started doing the squeak when braking and turning I thought it was the brakes. However, it didn't do that when I came to a complete stop without turning the wheels. So that baffled me a bit. I had it checked out and they said it probably was the wheel bearings. Nope they said it was fine.
Time passes by and now there is a new dilemma. The steering wheel was violently shaking when you apply the brakes. Obviously they have become warped and it couldn't be shaved any more. So I went out and bought high performance Cross-Dimpled rotors and it came with a brake pad deal.
After that, the turning + braking ordeal went away as well. I guess you can call it the ol' two birds with one stone theory.
Old Jun 14, 2005 | 03:41 PM
desertG's Avatar
Birdhouse,
You were right! I just got my G back from the dealership and they had to replace the front brakes and rotors. I haven't had a chance to see if the problem still occurs, but I think they took care of it.
Old Jun 14, 2005 | 04:31 PM
LuXXXz's Avatar
same **** is happening to me only when i have the car in reverse and i hit the brakes white turning, i have 34k miles on it, does warranty cover brakes and rotors?????
Old Jun 14, 2005 | 04:55 PM
desertG's Avatar
brakes and rotors should be covered to 36,000 miles.
Old Jun 14, 2005 | 10:08 PM
LuXXXz's Avatar
thats awesome thanks alot im definitely getting that done
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
