Borla Exhaust Rattling
Old Aug 4, 2005 | 10:36 PM
dschaefer's Avatar
I have an 05 6MT, the dealer installed the Borla before I bought the car. I love it except for the rattling when cold and starting off. Anyone solved this yet? Let me know...
Dave
Old Aug 5, 2005 | 12:49 PM
K-S-W's Avatar
I welded my borla on, no more rattles. Or you could check the clamps for tightness.
Old Aug 6, 2005 | 11:03 PM
dschaefer's Avatar
Anyone else have success taming this noise?
Old Aug 6, 2005 | 11:30 PM
skeleton_cru's Avatar
Sedan
I've had the Borla for well over a year and I've never had any rattling. It is not welded either.
Old Aug 7, 2005 | 01:43 PM
vdoalamo's Avatar
No rattles on mine. Mine in not welded. What are the pros and cons of welding? I kept my old factory exhaust just in case the next guy who buys it does like the low rpm drone.
Old Aug 7, 2005 | 02:07 PM
OCG35's Avatar
Check the mounting brackets and make sure the bolts haven’t rattled loose... My Stillen started rattling about a week after install... turns out they forgot to use lock-tight on a couple of mount bolts... After lock tight and tightening down the bolts it hasn’t rattled since.
Old Aug 7, 2005 | 06:10 PM
Sedan
I don't believe it's necessary to weld the Borla. It was designed as a bolt-on exhaust.
Old Aug 7, 2005 | 07:49 PM
kachme's Avatar
double check all your clamps & heat shields. We have had a couple cars come back for rattles & thta usually solved the problem....
Old Aug 17, 2005 | 02:07 PM
dschaefer's Avatar
One of the pipes coming off the driver side Cat is right up against a transmission mount. No space in between at all. Every time the motor flexes on the mounts, the pipe bangs into the trans mount...
Looks like all it needs is a adjustment. It is at the dealer now to see what they can do with it.
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
