Weird thing happened with VDC
Old Sep 12, 2005 | 08:02 PM
Blackjack's Avatar
So I was at a friends and of course, some of his friends wanted to see and ride in the G. So I was telling them the features VDC, VLSD, sport tuned suspension etc, then decided to show them how it worked.
I showed them that with VDC on, it was tough to peel out... Then I went into a cul-de-sac, turned VDC off and showed them how it worked. Gave it plenty of gas and cut the wheel. The odd thing was that after I did this the VDC off light would not go off and the Slip light also stayed on. I had to turn-off the car and restart for it to go back to normal. Did I just confuse the computer or what the hell happened?
Old Sep 12, 2005 | 08:09 PM
GeeWillikers's Avatar
Walking The Fine Line...
Sounds like you threw it into limp mode. How was performance after the lights illuminated and remained lit?
Old Sep 12, 2005 | 08:14 PM
Blackjack's Avatar
Actually it scared the **** out of me that I didn't try any other moves after I saw that. I immediately pulled into a neighborhood and restarted the car. That got things back to normal.
Should I have the dealer look into it or do you think it's just a "freak" thing?
EDIT: I should have searched first. I just found this: https://g35driver.com/forums/g35-coupe-v35-2003-07/65922-stuck-slip-light-vdc-off.html
I think I may have just really freaked the living **** out of the computer and it didn't know what was going on.
Old Sep 12, 2005 | 09:16 PM
Nickk6's Avatar
The car has two traction control systems. TCS and VDC so the other one was kicking in. You can only turn off the VDC so this will happen sometimes, happened to me before too.
Old Sep 13, 2005 | 09:09 AM
EDIT: I should have searched first. I just found this: https://g35driver.com/forums/showthread.php?t=65922
If the car has behaved normally since you did the restart, I'd write it off as a one-time incident and keep an eye on things for awhile. Most likely you freaked your VDC system out and it panicked.
Old Sep 13, 2005 | 10:00 AM
doogie's Avatar
When you turn off the VDC it's not TRULY off, there are still times during extreme maneuvers when it'll kick back in for safety.
However, when you turn it off and do a couple donuts, you'll get the light to stay on. Now VDC is REALLY off
Nothing to worry about, it's not a bug it's a "feature".... or something.
Old Sep 13, 2005 | 12:32 PM
Blackjack's Avatar
Good to know! I guess I can say I've done some "extreme maneuvers" in my G now.
Old Sep 13, 2005 | 03:12 PM
JohnNJ's Avatar
Thumbs up
Haha, that's an exclusive club. *thumbs up*
Mry
Mar 3, 2023 01:03 AM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
leo38cheng
Nov 12, 2015 06:49 PM
Ray Feta
Aug 13, 2015 11:40 PM
MsFitFern
Aug 9, 2015 02:58 PM
