optima battery in sedan?
Old Sep 8, 2006 | 09:30 PM
  #106
StarChamp's Avatar
Anybody know the specs on the OEM sedan battery? I know it's an 80D26L, but i find CCA specs anywhere from 445 to 582, and Ah from 40 to 55. I'm not running any ICE other than a couple extra gauges, just want a lighter replacement battery...but I need to know the OE specs first so I know which Optima/Odyssey to get. Thanks.
Old Sep 8, 2006 | 09:50 PM
  #107
khsonic03's Avatar
Check the manual. I'm almost positive it's in there.
Old Sep 9, 2006 | 10:24 AM
  #108
BigSash's Avatar
this whole thread is about which optima battery will fit. You only have two choices in yellow tops so just do the reading.
Old Sep 9, 2006 | 02:45 PM
  #109
mr_ecktid's Avatar
Just installed my D35 last week, works great, thanks everyone who helped me out!!
Old Sep 10, 2006 | 12:34 AM
  #110
StarChamp's Avatar
I guess I should have been a bit more specific; I'm relocating my battery to the trunk, so I'm not concerned about fitment. I just want the lightest battery possible within OEM specs. At this point I'm considering running two Optima 6v batteries in series for better wieght distribution.
Old Sep 12, 2006 | 07:28 PM
  #111
DaygoG35's Avatar
Optima D34/78
After reading the threads regarding Optima batteries, I am still not clear if my Optima D34/78 will fit in my G35 coupe. Want to intall a system and already have this battery from my previous car. Do I need an extender? If so, does anyone know where i can purchase one?
Old Sep 13, 2006 | 07:49 AM
  #112
Gilley's Avatar
The easiest way to see if it will fit is to pull out the battery that is there now and see if the Optoma that you already have will fit.
Old Sep 13, 2006 | 10:44 PM
  #113
RetAF's Avatar
They have this new high-tech device called a ruler or tape measure now. I think they teach operation at most community colleges. (We need a smiley for smart-****! My pain meds are really rocking tonight!)
Old Sep 13, 2006 | 11:10 PM
  #114
DaygoG35's Avatar
I am new to this forum and don't need smart remarks. If you don't have anything to add that is helpful then please don't post at all.
Old Sep 15, 2006 | 09:34 PM
  #115
RetAF's Avatar
If you don`t need smart remarks, don`t ask stupid questions. Do you not understand the concept of smilies to indicate jokes? Perhaps the comment telling you to test fit the battery was more illuminating for your mystery. Personally, I would rather move a ruler than a battery, but, to each his own. Grow up. If you are so easily offended, you will have a rough time in life.
Old Sep 16, 2006 | 07:49 PM
  #116
BigSash's Avatar
please step up the intelligence quotient
Old Oct 23, 2006 | 04:49 PM
  #117
Jeff92se's Avatar
Red Card Crew
Just an update. I finally got around to installing it. On their website, they mention that a bracket is included. Make sure you get it. Or else the battery is too small for the hold downs to work. Unless you rig a big spacer or something. But fits fine and works well.
Originally Posted by Jeff92se
Correct. But I can't find them in stock and it's backordered. I'm going with the Red 35. 33lbs and plenty of power. I don't have a huge system
Old Oct 23, 2006 | 05:07 PM
  #118
ttrank's Avatar
Grocery getter
Good point. I was not able to use the hold-down with my current battery.
Old Oct 23, 2006 | 05:11 PM
  #119
Jeff92se's Avatar
Red Card Crew
For reference. See in the notes below. The bracket actually comes with a large bracket with one small add on at the bottom. I tried using both but it was too tall. Remove the small one and it's perfect. When I first received the battery, it didn't come with one so I had to ask for it after the fact. Might save time to make sure you ask for the bracket specifically when ordering.
http://www.1st-optima-batteries.com/schema_35.asp
Old Oct 23, 2006 | 06:04 PM
  #120
digital1986's Avatar
Originally Posted by GEE PASTA
you will want the D35R yellow top. It will fit fine and you will be happy with the voltage.
damn, that must be nice for you amp
