ECU Reset
Old Jan 18, 2006 | 03:59 PM
RedruM's Avatar
ECU Reset
hey guys, i want to reset my ECU and i learned that the best way is to disconnect the battery for 2 hours. i was wondering when i do that, and the 2 hours pass do i have to get a jumper to jump it or all i gotta do is connect it again and start the engine?
Old Jan 18, 2006 | 04:08 PM
Jeff92se's Avatar
Red Card Crew
Question. Does resetting the ecu delete all the NAVI settings?
Old Jan 18, 2006 | 04:11 PM
Msedanman's Avatar
O.F. Administrator
It's best to disconnect it overnight (as the service manual suggest) but some do it for a shorter time.
After the reset, just reconnect the negative cable securely and you're good to go.
(If you disconnect the negative, black, cable, you have less chance of arcing)
C.
Old Jan 18, 2006 | 04:17 PM
Msedanman's Avatar
O.F. Administrator
Not all, and only if you reset by disconnecting the battery.
The average MPG's on the navi will go, as will radio presets, and trip odometers not biggie, but as I said only if you disconnect the battery.
If you do the pedal method described HERE in our FAQ forum, you'll lose nothing.
That method tho, takes a little practice.
G/L
C.
Old Jan 18, 2006 | 04:23 PM
louielou's Avatar
Left mine disconnected all night...@ least you'll know that somebody stupid will not steal your G.
Old Jan 18, 2006 | 05:01 PM
Jeff92se's Avatar
Red Card Crew
Thank you sirs for the info!
Old Jan 18, 2006 | 06:20 PM
RedruM's Avatar
thx guys for the info.
Old Jan 18, 2006 | 06:25 PM
RedruM's Avatar
but i dont dont get why people do the ECU reset? what happens when u do reset it? does it make the car better or something?
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
MThawkins86
Oct 24, 2015 02:07 AM
vamarris
Sep 26, 2015 12:56 PM
