G35 Brake Warranty
Worn brake pads are not covered under warranty plain and simple. They are considered a "wear" item. If it is normal wear (22,000 miles is normal wear) than you are responsible. The only way they would be covered is if there is some sort of manufacturers defect, driving and using the brakes is not a defect.
on
Originally Posted by Noremac
It helps to know all your facts before you speak so confidently. You are correct that wear and tear items are not normally covered, but there was a special 36/36warranty coverage added to 2003-2004 non-brembo cars just like the poster said above. Many of us have taken advantage of this.
Originally Posted by Easein2itG
There was a technical bulletin added for at least the 03 due to premature brake wear on the rotors and pads. The dealer replaced both my rotors and pads for free under warranty when the car had 22K miles. Check with your local service manager as I did and hopefully you'll get good news.
I see, I hadn't heard of that, mine is an 05. Normally the pads would not be warrantied for normal wear.
