A few gripes here
Old Dec 12, 2006 | 08:35 AM
  #76
Garnet Canuck's Avatar
Traveling Administrator
Originally Posted by RBull
Shane, I thought your garage was unheated and uninsulated?
Yes, that is correct Deane......it is unheated and uninsulated. I have found that even though my garage is unheated, it still keeps the vehicles out of the elements and the wind and they have never had a problem starting. I never even have to scrape the windows with the vehicles in the garage like I would if they were outside.
Old Dec 12, 2006 | 08:47 AM
  #77
RBull's Avatar
Rated M
Yes, having the garage is great in terms of keeping the car out of the elements. The block heater benefits the engine with reduced start up wear on the colder days though. It keeps the fluids warmer and thinner so oil will be more quickly circulated upon start up. Then again since you have a lease so you may not be as concerned!
Old Dec 12, 2006 | 12:09 PM
  #78
N50's Avatar
N50
Hey Alex, a block heater doesn't weigh more than a 1/4 -1/2 pound and the wiring a little more than that. It's a huge pain to remove it and put a plug in it's place and would have to be replaced before the lease return.
LOL. Thanks Shane. After looking over the pics again for the third time, I figured that out.
Old Dec 12, 2006 | 07:36 PM
  #79
RBull's Avatar
Rated M
No problem. You don't often see block heaters since they normally don't wear out. Nowadays they're factory installed in the frost plug holes in the block.
Deane
Daniel k.
Nov 3, 2015 09:52 AM
fecurtis
May 19, 2008 03:15 PM
G Wiz
V36 General Tech Questions
35
Sep 10, 2007 04:52 PM
