Aux. Input Question.
Originally Posted by hokiesean24
OK, so, if I am driving and playing music through my Zen the song info will not show on the Nav unit? Or does it distinguish between just the song info and video?
And if it doesnt show the song info, what does it show? Just what the audio source is?
You will see a basically grey screen that says "Aux" in the corner.
Hey, check this out... Could this actually work? It doesn't seem like it would be able to send video feed out through the headphone jack. If it could it would alleviate the problem of not being able to hook up the output to the Nav unit and hooking it to a car charger for longer trips?!?! What do you guys think?
http://cgi.ebay.com/FOR-CREATIVE-ZEN-VISION-M-30GB-AUDIO-VIDEO-AV-CABLE_W0QQitemZ290076690375QQihZ019QQcategoryZ114616QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/FOR-CREATIVE-ZEN...QQcmdZViewItem
But, as I said, this is all speculation on my part.
i took a look at the zen vision a while ago, and i thought it used a standard 1/8" minijack for all three signals (composite video, l/r audio).
If you look at a standard stereo l/r headphone jack, it has two segments. one for the left and one for the right channel. most video devices use a cable that has 3 segments, left, right and video.
This looks like what the zen vision is supposed to use. l/r stereo segment size is a fixed size and standardized thus any standard headphone jack will work with audio (unless you have a horribly stupid device). Usually, the standards don't leave alot of wiggle room for proprietary cables to do odd things with the video signal, thus in most cases the same cable tends to work. I believe that the apple ipod's video cable does something odd with the video signal separation which is why a custom cable is required, but the connector on the 1/8" jack is the same as any A/V 1/8" jack I think.
Visionnn
10-03-2015 05:16 AM
FreshVQ
09-30-2015 01:41 PM
