S.O.W. Settings
S.O.W. Settings
I have been tinkering with my settings to see which is the best. I usually have the fade one notch to the rear, bass at even, and the treble either one or two notches up...does anyone else in here change it depending on the type of music? I listen to most of my music off my IPOD via the RCA cables but the quality isn't that great. Ive used 3 different kinds of RCA and they all have their weaknesses. Too me the SOW is definetly alot better than a factory radio but im a little disapointed with the limitations BOSE set on it.
I have a one bar bias to the rear speakers as well. This seemed to help with what I felt was a lack of bass response (I am a bass player so I have to hear and feel the bass...). I am very happy with the sound of the SOW system now.
I have the fade two bars forward, well... because that's where I sit
I'll try it a few clicks back and see what difference that makes. I never thought to try that... <duh>
Balance is center
Bass- 2 clicks above middle for daily news and general driving, max when I'm doing my Mad Max routine.
Treble is max.
Another interesting question: What style of music do you all listen to on your SOW?
Everything in my car now: Finger Eleven, Godsmack, Velvet Revolver, Godsmack, Tool, Godsmack, and some more Godsmack
When I want to cruise it's Fiddy Cent...
I'll try it a few clicks back and see what difference that makes. I never thought to try that... <duh>Balance is center
Treble is max.
The stock Bose controls are crap IMO. I keep my signal flat and neutral as I don't trust the treble/bass circuitry to do the job properly. Looking into an external processor and a new HU to replace my Blose unit. The biggest gripe is the stock amp which is too weak to drive the rear deck 9x6s properly and pushes boomy bass instead of crisp and punchy bass. Then again, perhaps it's also because of the crap paper speakers made in Mexico that Infiniti puts in. I'm expecting big improvements with the '08 coupe.
Originally Posted by G35Now!
Bass and treble are +2, Fade is centered (I tried fade to the rear, didn't feel any extra bass...?).
This is listening to anything from Eminem to Pink Floyd.
Paper cones are more accurate and less colored sounding than poly material. They can also last just as long when treated properly.
Flat and centered all around. I'd prefer it if the SOW had a DIRECT setting to bypass the TCs...
