will the m45s shift knob fit on the 07 g35s
Old Dec 14, 2007 | 02:33 PM
  #91
Jason@Riverside's Avatar
Originally Posted by kre62
So the bottom line is in order to make the **** fit we have to cut 2 small grooves in the shaft in order to allow the little clip to slide in and secure the ****. Complicates things a little but still can be done.
Correct.
But, by only cutting the 2 small groves, the **** will sit at the same height as the G **** like the side by size photo I posted above...
Old Dec 14, 2007 | 02:34 PM
  #92
and I also just checked... The shift boot on the M is all black stiching and does not have the same sticthing as the ****...
  #93
viguera's Avatar
Only if you want it to sit lower... that's what I got from his last post.
If you don't care and you like your **** ( ) to be in the same position now, then you don't have to cut anything. Unless I'm reading this wrong.
  #94
kre62's Avatar
Is there a safe way to trim the shaft, or can we get M shafts and screw em in or something?
Old Dec 14, 2007 | 02:35 PM
  #95
To get the M shaft you would have to get the complete shifter assembly. not sure if it would be a direct swap either...
Old Dec 14, 2007 | 02:36 PM
  #96
kre62's Avatar
Ya you are reading it wrong. The M **** grooves wont reach where the grooves are on the G shaft, cause the M **** is shorter. So grooves will have to be cut in order to put the pin in and secure it. I dont know if youve looked at the ****, but it might help to go take it apart so you can see what Im talking about.
  #97
You do not have to cut unless you want it lower...
BUT, to have the **** installed correctly so it can not just be pulled up, two little notches would have to be cut into the side of the shifter shaft for the clip to install correctly...
I will photoshop what I mean...
Old Dec 14, 2007 | 02:38 PM
  #98
kre62's Avatar
We are talking two really small grooves. It could be done with a pocket knife as the part is plastic. The real question is does the **** look good enough at that height to bother dealing with it.
Old Dec 14, 2007 | 02:40 PM
  #99
kre62's Avatar
And I think the answer is yes. J whats the shipped price on the **** alone?
Old Dec 14, 2007 | 02:42 PM
  #100
Old Dec 14, 2007 | 02:44 PM
  #101
viguera's Avatar
Ok, I got it now... so if I don't cut the grooves, the thing will just slip out when I pull on it... that would be a bad thing.
But it sucks that the boot doesn't have the same stitching though. That's the selling point on the ****, and I guess that if you already have a black interior, you're basically getting the same boot that you have now.
So... I guess I'll take the **** only and leave my G boot.
Old Dec 14, 2007 | 02:46 PM
  #102
you can install the **** and see how it is to pull up before the **** comes off...
exactly, same boot as you have now...
I will post pricing on the **** alone now...
Old Dec 14, 2007 | 02:48 PM
  #103
Forum Member pricing for the Y50 Sport Shift ****!
Outside of California: $92.50
Inside of California: $99.31 (including Tax)
Old Dec 14, 2007 | 02:51 PM
  #104
kre62's Avatar
K send me the request
Old Dec 14, 2007 | 02:52 PM
  #105
kre62's Avatar
Got a request for 99.50 but Im in Nevada.....
