New owner- how to I get the analog clock backlight on? Brake vibration?
There is some good reading on brake warp here:
http://www.stoptech.com/tech_info/wp...akedisk.shtml#
on
I confirmed they (the clock and the ring around the navigation controller dial) do light up when it's dark and the auto-lights go on. However, in the daytime when I turned the lights fully on manually, I could not tell they were on at all becuase of the sunlight. I'd think they'd glow brighter like the dash gauge cluster. Oh well, might be better next week when I get tint.
I def. feel the brakes are strange and will take back to the dealer- think I might have warped rotors or something. Vibration noticeable on almost all stops or even slowing down from say 35-20, so that's not right.
If I'm taking it in, do you know if there are any dealer service level adjustments (electronic or mechanical) they can do to reduce power steering assist? I feel like I'd like it to be a little "tighter" but didn't know if anything can be done about that? I'm sure I'll get used to it. Loving the car overall!
Originally Posted by owls94
Unfortunately, my car also had the steering wheel "shake" while braking at high speeds. I took it in to the dealer and they replaced the rotors. I thought it was just me, but I guess it's a little more common. Other than this minor setback, the car is great and a blast to drive.
The rotors were a big enough problem on the 5th gen Maximas that Nissan issued a TSB on them. I hope I don't have the same issues with the G.
Originally Posted by G35Now!
I had a 2k3 Max, and sure enough the rotors were pretty lame. In the G though, have never had a problem even during the track day - no brake fade, no shudder. Maybe it's a batch quality control thing?
Same Problem - new post
can any of you guys weigh in? i just posted yesterday.
https://g35driver.com/forums/g35-sedan-v36-2007-08/221003-3-series-new-08-g35x-brakes-not-smooth.html
2007, analog, background, backlight, backlighting, clock, clockface, controller, g35, knob, light, sedan, steering, stopped, wheel
