Compass?
Old May 2, 2008 | 08:14 PM
g35xdriver's Avatar
g35x
you can turn the clock off on the nav screen.
i kinda like not having a compass in the rear view mirror. even if i didn't have navigation, i think i'd prefer not having that on the mirror.
Old May 2, 2008 | 09:27 PM
orion_21's Avatar
Originally Posted by 306HP
If you have NAV, the compass is on the NAV. I think this was intuitive thinking on the part of Infiniti. Why have a compass on the mirror and the NAV. My previous car had this set up and I always used to think this is so redundant, 2 things giving you the same info
Thats just my 2 cents
same reason they put a clock on the dash with nav I guess
Old May 2, 2008 | 11:18 PM
306HP's Avatar
Yes, thats also redundant having the clock on the navi as well. I switched the Navi clock off, I think Infiniti probably gave the drivers the option since some people would probably prefer to use the digital clock.
Old May 6, 2008 | 09:04 AM
mthowell's Avatar
Originally Posted by whtbst
on 07's with navi/prem, we have a compass on the rear view mirror AND navi screen. but i've noticed that the navi screen compass is wrong 90% of the time. the rear view mirror compass is always accurate, but the navi compass always seems to conflict. for example, the mirror compass will say NW while the navi compass 'points' toward NE. what's up with that?
Ok, I finally figured this out..sorry for anyone who knew the answer..the reason the compass is 'pointing' that way is because it is pointing to where north is. You have the option selected for your pointer to always be facing up..so the compass with the red tip..points to where north is, which is different from the actual direction you may be traveling..unless of course you are going north. If you chose to have north be up in your map options, your rearview mirror compass and the nav system would be the same.
Hope it helps.
Old May 6, 2008 | 02:53 PM
g35xdriver's Avatar
g35x
can the compass on the mirror be switched off?
Old May 6, 2008 | 05:02 PM
whtbst's Avatar
yes, there is a separate button next to the homelink buttons to disable the mirror compass (at least for the 07's).
Old May 6, 2008 | 05:24 PM
shabarivas's Avatar
Originally Posted by carz
compass comes with premium package...but will be removed if you have Nav package
except if you have a G37...which is weird...unless my car got screwed up.
umm i have an 05 6mt w/ nav and premium... i have a compass... its not on the mirror ... its to the left of my clock... OP: you can turn this display on and off
Old May 6, 2008 | 05:40 PM
whtbst's Avatar
Hope it helps.
THIS MAKES TOTAL SENSE TO ME NOW. thanks.
Gordgee
Interior
Apr 2, 2012 08:08 PM
PEARL-G
Apr 2, 2007 08:14 PM
ghostcoupe
Mar 22, 2007 08:54 PM
Corgidog
May 17, 2005 04:37 PM
BobT
Dec 10, 2004 06:17 PM
