no traction with 20's
I am new to this forum and this would be my the first questions I have. On my sedan I have 20x8.5 in front and 20x10 rear 275/35 toyo's. I have been putting performance parts on little by little (high flow cats, stillen stage 3 intake, stillen headers, stillen pulley, full stillen exhaust). My problem is car has no traction, when I leave the vdc on it cuts power way too much and when I take vdc off the rears slide through second. What kind of tire setup should I put on? I am trying not to go to an 18. Would a 275/40 19 work in the rear? Also what brand of tire would have the most traction. I was also thinking of finding a rear end out of a g35 sport with posi would that help with my wheel spin. thanks
![Dunno](https://g35driver.com/forums/images/smilies/dunno.gif)
We wanna help, but pls HELP us to HELP u!
![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
I'm putting down 310whp and 242wtq to the wheels and a ew days ago me and friend put some rims on my car to see how they look. I wanted to have some fun. They were 20x9 and 20x10.5 with 275/30/20 and 245/35/20 tires. I was taking 90 degree turns at 30-40mph and they were holding up fine.
And when I wanted to drift i would drift.
It might be from crapy tires, tire pressure, or your car has a problem.
I heard somewhere the rear end in the g35 sport is different and better than the one in the journey is this true?
Wiki: A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
