butt sag!
butt sag!
I was looking at my car and realized that the back is much lower than the front... as in the back wheel gap is like half of what the front is.. what fixes this? only if I get springs or coil overs? Also I am a very spirited driver and when Im taking turns I feel a bit to much body roll.. what do you recommend I do?
I don't think he wants to spend the money for coils.
There are a few spring kits that will suit your needs.
Do a search and check the marketplace.
Just keep in mind that it's not sag... it's the cut of the fenders.
Measure from the floor up to the jack points and see that the car is actually sitting level.
As mentioned above, there are spring options to make it "look" more level by actually geting the rear higher than the front.
Eibach has a new kit out for the X that accomplishes this.
