Car is donezo...off on a tow truck to the dealers...
Old 03-12-2011, 07:44 PM
Anton_Chigurh's Avatar
Now that I think of it. Car fax had at 6 oil changes on there but like 9 dealer visits up till 50000 miles.
Old 03-12-2011, 08:11 PM
Fendi35's Avatar
I just don't trust dealers bout my infiniti about a month ago dealer said he changed the oil all the brakes where good but I took it upon myself to change the oil and get the car checked out
When I was changing the oil the oil in the car was actually good but it wasn't synthetic so I put in mobile one fully synthecic
Old 03-12-2011, 08:17 PM
samsizzle's Avatar
damn hopefully you get a new car out of this or that your annoying vibration issue is alleviated along with this major problem. we got your back g brother
Old 03-12-2011, 09:48 PM
Theres no way Infiniti would give me a new car. What i am expecting them to say is it was abused by previous owner and we won't cover it...i will fight that until i die if that's the case
It sounds exactly like this
This guy spun a bearing in one of the cylinders...what can cause that?
Old 03-12-2011, 10:01 PM
NYYBaseball423's Avatar
^That is a horrific sound. Good luck man, hope everything turns out well for you and keep us posted.
Old 03-12-2011, 11:08 PM
When i heard the noise..it made me want to cry..i knew i would need a complete overhaul..the noise was so bad...
Old 03-13-2011, 12:28 AM
samsizzle's Avatar
is the car under warranty?
Old 03-13-2011, 01:10 AM
Yes..64,000 miles
No way i can afford what i think that costs.. which i believe is 5-8k
Old 03-13-2011, 06:54 AM
RemmyZero's Avatar
Anton - try not to worry, this should COMPLETELY be covered under the original warranty. whether or not it was abuse from the previous owner. it's not like they made you sign something that said "the previous owner abused this vehicle therefore the following is not covered...."
i haven't heard the video yet but i'll do so when i leave work tonight. it sucks that it had to end this way but at least you'll get some resolution and get it fixed. i'm wondering if it was your crank shaft.....who knows....
and as far as spinning a bearing it's typically due to improper installation (which i would believe is rare), a warped bearing (resulting from time and wear usually since it's not likely they would knowingly install a warped bearing at the factory) or excessive wear due to improper clearances (i.e. - poor lubrication, foreign material in the oil scraping the surface, etc.). this will, in fact, produce a loud knocking sound.
i would find it very very hard to believe they would say this is your fault. i was told it's not required for me to keep records of my oil changes so i doubt they would ask it of you. they'll have to assume manufacturer defect. good luck!
Old 03-13-2011, 10:03 AM
gtbigup01's Avatar
Sorry about your car bro hope they can resolve it quickly and get you back on the street.
RemmZero: Who told you keeping records isn't required? You'd be saying something different if you needed warranty repair and the dealer thought it was your fault for not maintaining your car. BTW that little maintenance log they issue with every car is for a reason. If they want to play hardball you'd have no proof youve been taking care of your car.
Old 03-13-2011, 11:13 AM
preston8o8's Avatar
oh wow that sucks hope everything works out for you
Old 03-13-2011, 11:33 AM
I bought it 3 months ago from a non infiniti dealer...haven't needed to change oil yet so i have no records at all
Old 03-13-2011, 11:42 AM
Hi-TechG35's Avatar
Location: Pothole Central and still ridin slammed...Boston
Wow that's crazy bro. Just hope for the best. If you need a motor let me know I can possibly get you a good hookup as you know the stealership is always going to do what they do best and that's rape anyone they can on price. Keep us posted.
Old 03-13-2011, 12:20 PM
RedBaronK's Avatar
sorry man, i hope they will give you a new engine or something.
could this be related to the oil consumption issue?
  #30
Old 03-13-2011, 12:22 PM
As far as i know 2nd gen didn't have this problem
Quick Reply: Car is donezo...off on a tow truck to the dealers...
