Sparks from connecting negative terminal
Old Apr 18, 2011 | 08:03 PM
eddystone's Avatar
I disconnected my negative terminal to clear a CEL but when I was trying to put it back, it started to spark but I was able to put it on quick and that was fine. Why is this?
I also notice that it will only spark when the side edge will touch the terminal. It would spark and feel like its welding if I was to leave it. It left spark marks on the terminal.
Old Apr 18, 2011 | 09:49 PM
mishmosh's Avatar
There is current going through as soon as the metals touch, hence the spark.
Old Apr 18, 2011 | 09:59 PM
newlo-g35's Avatar
is your cable ok
Old Apr 18, 2011 | 10:00 PM
newlo-g35's Avatar
if your cable is ok check for a bad ground,
always disconnect the positive first and connect the negative first
Old Apr 18, 2011 | 10:01 PM
newlo-g35's Avatar
Old Apr 18, 2011 | 10:18 PM
BionicG35's Avatar
^that is incorrect. You ALWAYS make and break the connection w the ground
Old Apr 18, 2011 | 10:31 PM
eddystone's Avatar
My cable is good almost looks new. How would I get to see for bad grounding? I already bought the Blackbetty grounding kit but hasn't arrive yet but will be installing those right away.
Old Apr 19, 2011 | 02:59 AM
vqsmile's Avatar
+1 to the first reply.
Think of it this way: As your car sits (engine off) at any given time, it's consuming power from the battery (clock, ecu, alarm system, aftermarket stereo equipment, lights for any door or hood you may have opened, etc.) until the engine is running. This is why your battery will eventually go dead if you don't drive it often enough to keep it recharged. So anyway, just prior to connecting your battery terminal, all those circuits are enabled and ready to permit current flow the instant you complete the circuit. The arc that you see is the total current demand of all those circuits simultaneously powering up. This is normal. Just attach it quickly and don't fiddle around making and breaking the circuit over and over while you "settle" the terminal into place.
Remember, this is low voltage DC circuitry. Thus, there is a LOT of current flow required to make up the required power demands (since P=V*I, and V is fixed at 12v). In a pinch, you could quite literally weld metal with your little car battery; you're just seeing a very small sample of it and hence the light show.
Old Apr 19, 2011 | 09:11 AM
eddystone's Avatar
Thanks for the explanation. I was just so worry that something is really wrong with the car now.
Old Apr 19, 2011 | 10:32 AM
kool_yaar's Avatar
its normal like mismosh said its just cause of the accessories suck current as soon as the neg touches any metal.
i think you got it a little mixed up, its like bionic said negative off first to disconnect and connect if your planning to take both terminals off. The rule you might be confusing it with is that when connecting back then the positive goes first.
Old Apr 20, 2011 | 05:02 PM
newlo-g35's Avatar
Red face
yeah sorry about that
Old Apr 20, 2011 | 06:49 PM
kool_yaar's Avatar
^ no biggie, after a dozen years of working with cars and such i can still mix up the "simple" lefty loosey, righty tighty rule...
Old Apr 21, 2011 | 09:02 AM
RemmyZero's Avatar
yeah i'm late to the party here....yes this is normal, it's just how electricity works, no need for concern. keep in mind though that this is also why it's recommended to connect jumper cable grounds to the body of the car and not the battery. lead-acid batteries vent hydrogen as they discharge, increasing the possibility of an explosion from a spark. just a safety tip.
Marlin84
Apr 1, 2020 12:52 PM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
g.spot
May 9, 2016 10:54 PM
KallDay86
Jan 8, 2016 12:42 AM
vamarris
Sep 26, 2015 12:56 PM
