Cold Air Intake...Injen/Stillen
Old May 13, 2011 | 02:40 PM
arok5's Avatar
Hey guys,
I'm looking to install a new intake on my G35. I'm torn between the Injen Cold Air Intake system OR the STILLEN Generation 2 Long Tube Dual Intake Kit.
Does anyone have any personal experience or opinions on which one I should go with (or not do this at all), etc.
Also, pros and cons of doing a new intake?
Any feedback helps...thanks so much!
Adam
Old May 13, 2011 | 03:57 PM
mishmosh's Avatar
Stillen gen3!
Old May 13, 2011 | 04:43 PM
DFWG35driver's Avatar
Injen Sp1997P is treating me good!
Old May 14, 2011 | 03:16 AM
KulG35's Avatar
Gen 3... Otherwise injen
Old May 14, 2011 | 03:38 AM
sdonabo's Avatar
injen all the way
injen is like infiniti
stillen is like nissan
imo
i love my injen cai
stillen is also good i want their pulley exhaust and headers
Old May 14, 2011 | 01:32 PM
Q8y_drifter's Avatar
Stillen G3, only because they both give you about the same power but Stillen's filter placement is much easier to access for cleaning.
Old May 14, 2011 | 02:17 PM
Indeed the G3 filter cleaning is MUCH easier, the Injen you have to pull the front clip back off to clean them.... I figure once a year cleaning isn't bad though.
Old May 14, 2011 | 02:25 PM
KulG35's Avatar
Stillen is less likely for hydrolock as well v stillen g3
Old May 14, 2011 | 02:56 PM
A LOT less likely for hydrolock! I had to chill under an overpass for an hour and a half the other day because the rains came so sudden there were pools every where and I wasn't risking the motor.
Old May 14, 2011 | 03:09 PM
Install on the Ijen CAI's. You can see they are VERY low.
Attached Thumbnails Cold Air Intake...Injen/Stillen-injen2.jpg   Cold Air Intake...Injen/Stillen-injen4.jpg   Cold Air Intake...Injen/Stillen-injen3.jpg   Cold Air Intake...Injen/Stillen-injen5.jpg   Cold Air Intake...Injen/Stillen-225201_1895826669834_1066609388_2132363_2664255_n.jpg
Old May 14, 2011 | 04:38 PM
djfarhan's Avatar
gen 3!
Old May 14, 2011 | 05:34 PM
AesonVirus's Avatar
I'd choose almost anything over the Stillen Gen 2.
Comparing the Injen CAI to the Stillen Gen 2 is apples to oranges.
You should be comparing the Stillen Gen 2 to the Injen SRI -or- the Stillen Gen 3 to the Injen CAI
Old May 14, 2011 | 05:48 PM
dankG35's Avatar
i like the stillen gen2 a lot. gen3 is too much of a hassle to install since you have to cut the frame inside of your hood.
gen 2 is easy to install yourself
Old May 15, 2011 | 09:24 AM
Fendi35's Avatar
If it rains a lot where you live i would not recommend injen i had the cai system took on water way to much even with the hydrosheilds go for the stillen
Old May 16, 2011 | 02:17 AM
Kube929's Avatar
Stillen gen 3!!
KruZZe
Feb 27, 2023 05:04 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
