DS / manual mode won't work..
Old Jun 3, 2011 | 03:43 PM
soakgame's Avatar
I switch to DS mode, change gears (+/-) with the auto stick, but it goes back to D and won't respond. It responds to paddle shifting, but not the stick. I have to turn the car off and on for the DS mode to show up again.
Has anyone else had this problem?
Old Jun 3, 2011 | 03:45 PM
E-Ticket Ride's Avatar
The trans switch is probably broken.
Old Jun 3, 2011 | 04:39 PM
ericks_G's Avatar
Originally Posted by e-ticket ride
the trans switch is probably broken.
^+1
Old Jun 3, 2011 | 08:07 PM
bluedevils95's Avatar
trouble shoot the problem and fix it.
wait! Is your G still under warranty? If so, get it fix that way.
Old Jun 18, 2011 | 11:10 PM
soakgame's Avatar
how much to fix?
i also tried to reset the ECU just to see if that would do anything... but for some reason i'm having trouble doing it.. i've done it a couple times before in the past
Old Jun 18, 2011 | 11:14 PM
soakgame's Avatar
nope.. warranty expired after 60k.. i'm at about 76k now
love the car.. but i'm starting to have small issues with it
- broken left rear window (won't open from my driver switch)
- fog light issue (turning off and on randomly)
- and now the tranny switch issue
Old Jun 19, 2011 | 08:31 PM
Holmes35's Avatar
I have the same issue with mine...D/S mode goes back to D mode by itself... I am at about 75k miles and sometime it acts up and sometimes it's fine
Old Jun 19, 2011 | 10:39 PM
Resetting the ecu wont solve the problem. I'll post the part number of the part they replaced for my car later.
Old Jun 20, 2011 | 11:35 AM
Holmes35's Avatar
thanks man i would really appreciate it and i am sure many more members will have this problem in the future.
Old Jun 20, 2011 | 02:12 PM
soakgame's Avatar
thanks.. appreciate it
Old Jun 20, 2011 | 03:40 PM
ugaexploder's Avatar
the dealer had to replace my shifter solenoid and one other part, which may be the trans switch you guys are talking about. had it replaced under warranty because car was doing the same thing, good luck.
Old Jun 21, 2011 | 08:42 AM
celwin's Avatar
That should be covered under the power train warranty (not the basic 60k warranty). in your case even the power train warranty expired. i'ts 6yr/70k
Old Jun 22, 2011 | 06:10 PM
Here's the part number they replaced:
"Device Assy Transmis 34901-JK60C," " replaced shifter assembly"
Old Jun 22, 2011 | 09:44 PM
kool_yaar's Avatar
^ good share
@celwin: even though i agree that this part should be covered under powertrain warranty, i read a post here by a member who said the dealer denied covering it under it and would only do it under the BtoB 4yr/60k cause its an electronic issue and nothing to do with the "mechanical" powertrain... which is BS but what can you do...
The OP should at least ask his dealer and maybe they'll cover it since every dealer seems to follow their own warranty rules
