SOLVED Vibrations at highway speeds
(Posting so this has a chance to help someone else)
2008 G35x
I recently had the dealer put on new tires. This was the first time I had the dealer do it, vs the specialist shop where I normally get my tires done.
For the next few days, I consistently experienced bad vibrations at 65+ MPH. The vibrations felt equally strong through the seat as well as through the steering wheel, In other words, the problem did not obviously seem to be coming from the front end vs the rear.
So I figured wheel balance was off.
I went back to the dealer. One of their mechanics patiently troubleshot with me, including flipping the tires around on each wheel, which seemed to help a little, as well as swapping on a different set from another car on their lot. There was no change in behavior with the other set of wheels, so I concluded the problem was somewhere in my car, and not due to a bad wheel balance job.
In this same timeframe I had noticed that my left rear wheel seemed to be hotter than normal after one morning commute. After the morning I spent at the dealer troubleshooting the vibrations, I took the temperature of the rotor with a laser thermometer: > 300 degrees F, vs @120 F for the other side ! So, apparent stuck caliper.
I replaced the caliper the next day (easy job on the G35x) and solved that problem.
On the very next commute, I noticed: the vibration at high speeds was gone !
So all along the bad vibrations were due to a stuck caliper.
2008 G35x
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
I had the same problem last month. I started to notice a smell when I would exit the car, then the vibration / shudder started. I put my hand at the wheel on all 4 sides and found the hot one right away. This was on the rear of my 08' G35x with 125k miles. I'm pretty sure my brothers 08' is doing the same thing.
Do you guys do anything to avoid sticking pins? I've heard people recommend NOT applying grease in the slide pins as you typically would on most cars. Last time I did my rear brakes, my dad applied grease to a pin without letting me know, and that was the one which stuck on the caliper.
apparently the caliper guide bolts have a rubber ring on them that swells up and prevents the caliper from sliding properly if you don't use the right grease. I called many Nissan/Infiniti dealers to ask what grease it calls for and they all told me synthetic caliper grease from any parts store would be fine..hehehe WRONG! I now have 5 different types of caliper grease, synthetic, moly, blah blah blah...finally tried 100% silicone grease (spark plug boot grease)and it works.
On my 08' it was the piston not retreating like it should. I only replaced the caliper with a reman unit and reused my pins and brackets. I always use high temp grease designed for disc brake applications. I have had to rebuild quite a few G20 rear calipers myself since they cost big $$$ these days and almost every one that I have disassembled have had erosion on the pistons. I wish I would have tore down the G35 caliper to see if it was a similar problem.
After I put it back together and drove the car, I smelled something off and pulled over. One of my rotors were cooking. I let it cool down for a bit, drove it home and took the pads off again. I figured it was the slide pins and clean them out, then pushed the piston back in again to reinstall everything. Maybe it was actually the piston instead of the pins.
same here g35 rwd first gen
2008 G35x
2008 G35x
To anybody reading this in the future, a stuck caliper will put off noticeably more heat than it's non-stuck counterpart. Take a quick drive on the highway then pull over, put your hand near the center of the rear wheels, the stuck side will be considerably hotter.
This issue is what ultimately made me swap out for OE Brembos. Also OE Brembos look cool and make me feel like the special boy my momma always told me I was c:
LaConic2
Mar 28, 2009 06:20 PM
