Bank 1 VTC Cover Removal
Old Sep 29, 2021 | 02:37 PM
  #106
deet-ex35's Avatar
Infiniti ex 35
Originally Posted by deet-ex35
Haha yes there was definitely pain in the process! thanks a lot man! Will update again after two weeks of driving.
final update: Over 200 miles driven, codes haven’t returned and no more low-speed stalling. Still can’t believe I have fixed the issue. Definitely won’t be buying an Infiniti again lol. Thanks for your help and good luck to anyone taking on this repair. It can be done!
Old Sep 29, 2021 | 04:04 PM
  #107
Ragnar Lothbrok's Avatar
G35X
Now your ready to replace the galley gasket. Hooray! Seriously saved yourself some coin and you know your VQ that much better. Carry on!
Old Sep 29, 2021 | 10:11 PM
  #108
pjensen's Avatar
Infinity G35
Did you end up buying a new cover from the dealership? Or a used one?
Old Sep 29, 2021 | 10:58 PM
  #109
deet-ex35's Avatar
Infiniti ex 35
Hi there, yeah I bought used ones off eBay. Both cost me about $450 in total.
Old Sep 29, 2021 | 11:01 PM
  #110
deet-ex35's Avatar
Infiniti ex 35
haha yeah definitely not scared to do any fix now (but I would rather not have to do any fix lol.. I didn’t really enjoy fixing the car.
And “galley gasket”? That’s something I have to do as well lol because I’ve read about it somewhere.
Old Oct 1, 2021 | 12:08 PM
  #111
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Interesting you mention that, I think these cars are pretty easy to work on compared to most modern stuff. The only component that's actually difficult to remove is the stock headers. Everything else mechanically speaking is very straightforward, sure it might have quite a few components to remove but at least they're all accessible.
Plus there's a huge amount of resources available for FREE to help you out, things like these forums, and the ENTIRE factory service manual available online for FREE! You won't find that on most other cars, end up using a Haynes/Chilton manual and trying to just figure it out yourself.
As for the galley gasket, I wouldn't bother with it unless you are actually throwing the P0011 or P0021 codes, or if you have the timing chain off for any reason.
Old Oct 1, 2021 | 12:35 PM
  #112
G35X
Thank you for clarifying my statement. I would in no way encourage anyone to change the gally gasket unless your throwing the codes mentioned. I bought an oil pressure gauge and have been checking the oil pressure every 6 months or so and so far so good.
Old Oct 6, 2021 | 09:10 PM
  #113
G35X
Went with the harbor freight kit. Works great!
Old Mar 24, 2022 | 01:25 AM
  #114
Ncard137's Avatar
coupe/custom paint/black leather interior/manual transmission/ rev-up/ 2+2
Exclamation 05 Infiniti G35 MT, vct cover assembly sourcing
Just to verify you're trying to replace this part right?
Im having issues sourcing this part. I have 2 mechanics and myself looking to find this part for an 05 infiniti G35 rev addition Manual.
But im told its on back order and has no price and no estimation of when it would be available.
Ive checked infinitiusa.com and z1motorsports.com as listed above but neither have that part for an 05 G35 or they have not responded
-- any help is appreciated
Old Mar 24, 2022 | 01:30 AM
  #115
Ncard137's Avatar
Im having issues sourcing this part. I have 2 mechanics and myself looking to find this part for an 05 Infiniti G35 Rev Addition Manual.
id like to just source the part brand new so i dont have to chance getting a broken part on ebay, but i cant find it anywhere
-- any help is greatly appreciated
Old May 27, 2022 | 08:09 AM
  #116
WaelNour's Avatar
Vq35hr
Please heeeelp
Hello guys
pleeeeeeease help me with my couple of questions
finally I found straight thread talking about my exact issue 🙏🙏🙏🙏
I having same problem that rpm sputtering and hesitating after warm up around 1k rpm
Now I have confirmed that I have this hesitating because my vtc after these following tests
Please note that my oil pressure is after fully warm up is around 8-10 psi / 2000k rpm around 40psi / cold start 80 psi , so i need to replace gallery gasket later too once I get low oil pressure codes or oil light on , I am living in dubai with almost some days 43 degrees weather I did manual relearn and OBVIOUSLY car is almost 90% better never like before
here the results after I unplugged my vtc and drive it
1 - disconnected both sides = issue gone completely
2 - disconnected right side = issue gone completely
3 - disconnected left side = issue gone completely
4 - plugged both sides = got the issue back
Pleeeeeease my questions
do I need to replace both whole cover or the magnets since I can’t find which one is Bad ?
do I need to replace them then do ecu update at the dealership or just replace and relearn ?
is it timing issue related with ecu or worn part ?
or just I need ecu update?
please waiting for any help I spent really a lot of money and now fix
Old May 31, 2022 | 11:29 AM
  #117
G35X
Well, I would start by understanding which bank is causing your issue. You need to read the DTC. From there you can replace the VTC for the bank causing the issue. Replacing the VTC usually clears up this stuttering low rpm issue.
Old May 31, 2022 | 03:12 PM
  #118
Brad6080's Avatar
base 04 sedan and 07 sport sedan
Just a quick update. Replaced both magnets with earlier posted pat number and issue hasn't returned over almost a year and about 10,000 miles. Stalling from a stop has also not returned.
Old May 31, 2022 | 03:24 PM
  #119
G35X
That’s good news. I just replaced Bank2 and that dam magnet was a bear to get out. It took an hour or so of cussing but it finally dropped right out. Now I have an A/C climate control issue. I wonder how old I will be when I finally get ahead of all my repairs. Lol
Old May 31, 2022 | 04:05 PM
  #120
Ncard137's Avatar
with roughly the same issue i was told to spend $2600 on new VTC covers which i did. Turns out my original VTC covers had 0 issues. Id be willing to sell you the VTC cover i have for less then what i paid for them/.
As it turns out my timing chain snapped on which the mechanics who installed the VTC covers...…. (didn't even look)
which caused the piston to possibly kiss the valves which means the engine needs a whole rebuild.
But when i was told to buy the VTC covers it was because Nissan makes the actuator on the inside of the cover and you cant just replace the solenoids on the outside of the VTC cover you also have to replace the cover itself.
Which now im finding out if your replacing the VTC cover; you should be removing the old sprockets and chain off with it.
