slight hesitation on slow take off
Old May 19, 2025 | 01:31 PM
  #46
Jux's Avatar
Jux
G35s
Originally Posted by foreste1
I went ahead and ordered the whole passenger tube and part from Infiniti, so its on its way, hoping this solves all these weird problems after new ac condenser and serpentine belt and receiver dryer were all replaced. My theory is when they took off the intake hoses that part was brittle already and created a whole, sounds like a bad part to begin with since others have same hole. Will let you guys know if this fixes the hesitation etc.
Hi, I know this have been over 2 years. Was your issue solved? I'm having the same problem
Old May 19, 2025 | 04:15 PM
  #47
MaLPoPieS's Avatar
Jaguar XFR-S
Check if your ECM has a firmware update available and if it does like mine did, then the hesitation goes away, assuming you have no other fault codes present.
Here, read this thread about ECM update at home, I start in post #4.
Guide for Reprogramming Updates to your ECU
Old May 20, 2025 | 10:28 AM
  #48
Jux's Avatar
Jux
G35s
Originally Posted by MaLPoPieS
Check if your ECm has a firmware update available and if it does like mine did, then the hesitation goes away, assuming you have no other fault codes present.
I've already done the ECM update.
Also, after reading your threads seems like your problems came back as well after your update.
Old May 20, 2025 | 12:56 PM
  #49
MaLPoPieS's Avatar
Jaguar XFR-S
I'm glad you read it at least, but heres why it came back.
Before the ECM update, i've replaced all 4 CAM sensors with RockAuto Hitachi cam sensors, thinking it would resolve my part throttle hesitation and those did this: Long and rough warm or hot restarts
So after putting back my original Denso cam sensors, ALL issues went away. It's been over a year and i haven't had a singel issue with my car drivetrain wise. So if you are on the latest ECM firmware software, then i would attack the cam sensors and get only OEM Denso ones from the dealer or you'll end up swapping parts and wasting time like i did.
Old May 20, 2025 | 01:09 PM
  #50
Jux's Avatar
Jux
G35s
Got you.
Thank you for the info. I really appreciate that
SmokingSkull
Jan 31, 2023 09:55 AM
dickersonka
Dec 28, 2011 01:01 PM
bluestacy04
Jul 5, 2011 03:32 PM
NewGuyG35
Aug 18, 2009 11:00 PM
max2k1
V36 General Tech Questions
51
Jan 30, 2009 05:44 PM
