Switch over to Synthetic Oil?
on
i'm almost at 38k miles, and I need to do an oil change but I was wanting to switch to synthetic...
after some researching, all of the threads i've read so far dealing with synthetic oil changes has been after the first or 2nd oil change...is it like...not good to switch over to synthetic now or what? how does it all work? and why the hell is it so hard to change the sparkplugs?
You haven't been running synthetic oil in your car? I would put your car up on jackstands...drain the oil and just leave the oil plug out all night and let as much as possible drain out. Put in a cheaper synthetic (pennzoil or castrol)let the car run for a couple hours or something and then change it again with mobil 1.
-Sean
-Sean
-Sean
-Sean
Originally Posted by tragedycat
I'm at 32k miles and changing to synthetic my next oil change prob in 2 weeks. I was just planning to put in some Mobil 1 and call it a day though, without any of the letting it drain overnight and switching it again and all that stuff. Does it really matter?
-Sean
Putting in a oil and letting it run and then draining it again probably doesn't do much at all. If anything it will just help get out of some that "crap" oil. I would let it drain for atleast a couple hours to get out as much as possible.
-Sean
-Sean
This is some of the worse advice I've ever seen. Just change it out with your choice of quality synthetic(pennzoil platinum+german castrol>=mobil 1) and use a normal change interval. No need to "flush" the "crap" oil. What a waste
-Sean
on
Originally Posted by chinabean
so then its okay to just switch it over? I mean Yeah i could do the oveernight thing i guess, but not sure about putting in the cheaper syn and then put quality syn cause that would be a waste of my $$$ lol
-Sean
Like i said, putting in a cheaper synthetic oil and then draining it again probably won't do much at all. It will just help get out of some of the old dino oil. You don't have to let the car sit over night either. Just a couple hours. Get out as much of that dino oil as possible.
-Sean
-Sean
Red Card Crew
If you change your oil at fairly frequent intervals, it almost doesn't matter which oil you use. That is if you are NA and drive somewhat normal. I'll admit, I change at around 4k and have used Castrol, Mobil 1 and I'm now on Penzoil Platinum. I'm hoping the PP has a better oil consumption rate than the Mobil.
In short, you're okay to switch at almost anytime as long as the engine is in good working order and you're not using some odd ball ultra thin stuff.
Even if you go to a Mobil 1 or Penzoil Plat, they are still made from non-sythentic base stocks.
If you want a true synthetic, you have to go to something like Amsoil.
