AC blowing HOT air!
AC blowing HOT air!
i have a 05 AT coupe with 43xxxmiles on it. i just turned on da AC today and it started blowing hot air. so maybe i thought it was cuz i haven't been using it all winter so i sat there and waited for a while and it was kept on blowing hot air! and when i turn da AC on i can hear da AC compressor kicking it. so what could it b?!?!? i'm thinking i need to go charge da freon. but it worked fine last year. i searched and searched in da tech section and i couldn't find anything about AC blowing hot air. i need 2 fix this b4 summer comes cuz where i live it gets over 100 degrees in summer! thanx guys!
I agree. First check your radiator fluid level. Next, you may want to think about getting your A/C system checked for leaks. Sure you could get it recharged but if there is a leak, you will be back to square one sooner than later. Good luck!
ya my radiator fluid level is low but not below da line. so i don't think thats not it. today i tried 2 turn da AC on again and for like da first couple seconds cool air blew and then it turned into hot. i just changed stock intake box 2 popcharger couple times past month cuz i had 2 take my car in for powertrain warranty work done. maybe i disconnected something there?!? is there anything major by da intake?!?
my 2003.5 started having this problem at the first on after winter. Infiniti dealer told me I need the compressor and belt for $1400. Did I hear right? $1150 just for compressor.
R U SERIOUS?!? I FVCKIN HOPE ITS NOT that in my car. cuz i can't afford plus summers right around da corner. and it gets 100+ degrees out here during summer!
Learned Hand
Oct 1, 2015 09:02 AM
master111
Sep 25, 2015 08:32 PM
