New DIY mod: 2007+ Altima "Fat Boy" exhaust tips
Old Nov 1, 2007 | 01:57 AM
DaveB's Avatar
I'm pretty excited about this new DIY mod. I've been searching for well over 2 years for the right exhaust tips for my G35's stock muffler. The stock tips, while large for OEM (3.1" wide, 2.7" tall), where simply too short (5") and just didn't exhibit the display of power I wanted especially after adding the 05 sedan midpipe. I searched and searched and I just couldn't find anything to meet my needs which were:
1) ~7" long housing so that tip could sit up flush against muffler can and go flush with the bumper.
2) Slightly larger in diameter. Idealy round.
3) Slash cut and rolled edge like OEM.
Well, I finally found the tips. They're from the 2007 Altima. My friend has an 2007 Altima 2.5s and he installed some ricer Stillen exhaust and said I could have tips. They measure 7.1" long, slash cut and rolled edge, and 3.5" in diameter round. They're perfect. I have given them the name, Fat Boys Look at the difference between the stock tips and the Altima tips:
It takes every little to modify these tips to fit. I have no idea what the cost is for the tips from Nissan, but I can't imagine they'd be anymore than $40 each. Here's the DIY:
1) Using a pair of tin snips, cut the inner portion of OEM mounting flange inside the tip. You'll make six initial cuts. The point of this that each of these 6 prongs will serve as mounts and centering points for the tip on the muffler pipes.
2) Inner portion cut
3) Next you'll need to cut the edges off a couple of the prongs near the lower portion of the tip because if you don't they'll stick out of the tip when you mount up the tip.
Prongs sticking out from tip edge
Prongs cut
4) Remove the OEM tips. There is no need to remove welded mounting bracket on the muffler pipes. The Altima tips are large enough to slide over this bracket.
5) Take the Altima tips and slide them on. It will take some elbow grease to get them on. It will be tight because those prongs will be grabbing into the muffler pipes (like you want).
6) They will fit pretty tightly and friction hold them in place just like the way Nissan fit the tip to the muffler pipes on the Altima. There are no screws holding them in place. I will be checking the tips periodically to make sure they're not loosening up. I may use solder gun or a few dabs of JB weld to hold the tips in place just as a precaution, but as of right now, they're very tight and going no where.
Finished product. I'll post better pics in the daylight. Also provided is a pic of the OEM tips. Note how tiny they look in comparison.
Stock -POS!
Finished product
Old Nov 1, 2007 | 02:13 AM
abailey269's Avatar
That looks awesome! Nice mod and great post.
Old Nov 1, 2007 | 07:50 AM
NathanJax's Avatar
..... I WIN .....
Looks GREAT !!!!
Old Nov 1, 2007 | 08:30 AM
sdnpaul5at's Avatar
Very nice!! we should get a group buy going.
Old Nov 1, 2007 | 09:06 AM
CandlestickPark's Avatar
ill Sedan
Looks good man. Nice DIY.
Old Nov 1, 2007 | 09:42 AM
04G35NYC's Avatar
looks great.
Old Nov 1, 2007 | 10:12 AM
Yv12345vY's Avatar
+1 for group buy!
VQ Hotness's Avatar
Nice mod for the OEM rear muffler. Looks nice!
Old Nov 1, 2007 | 10:21 AM
bert039's Avatar
I should just go outside and check my car but, how did you take off the stock G tips? Is it just a nut and bolt holding it in?
Old Nov 1, 2007 | 10:24 AM
Yv12345vY's Avatar
^ Looks like a screw on the far end. Look at the 1st pic.
Old Nov 1, 2007 | 10:32 AM
DaveB's Avatar
Daytime picture:
Old Nov 1, 2007 | 10:33 AM
DaveB's Avatar
Two nuts hold on each tip. Chances are when you try to remove the bolts, they'll shear off.
Old Nov 1, 2007 | 10:36 AM
Gilley's Avatar
That's a nice mod.
Old Nov 1, 2007 | 11:03 AM
Tunerz_Store's Avatar
Thats it! After I put on the nismo lip, the oem tips car barely been seen. I feel sorry for the next Altima I see........J/K.
Old Nov 1, 2007 | 11:07 AM
sdnpaul5at's Avatar
Damn, daytime pic looks even better!!! ok I'm calling Nissan...
