Stillen CAI dry filter replacement.
Old Mar 23, 2009 | 11:40 PM
  #76
OCG35's Avatar
^^^ your pic corroborates what I said (based on measuring the filter media only, not accounting for the metal top or any part of the rubber collar – I measured this way based on the diagram on AmsOil website)... 4.25" vs 6.5" is a very big difference... the closest Ams is 6.5" long.
I have looked at the area near the composite core support - there isn’t enough room.
Stop trying to convince me otherwise Jeff... just buy one, do whatever you think needs to be done to make it work and post up your results.
Old Mar 23, 2009 | 11:55 PM
  #77
Jeff92se's Avatar
Red Card Crew
You'll be the 1st person I contact.
Old Jun 2, 2009 | 03:35 PM
  #78
Swivel's Avatar
Moderator
Has anyone thought of writing to K&N to find out the PN? Mine just went in a couple weeks ago, clean and oiled, and it ain't comin' out anytime soon!
Here's something that may or may not help, the only two with a media height of 5":
AMSOIL#/K&N#/Product Style/FlangeType/BaseOD (in)/FlangeID (in)/MediaHeight (in)/TopOD (in)
EaAU3050 RU-3570 Round Tapered Center 6.000 3.000 5.000 5.0
EaAU3051 RU-3580 Round Tapered Center 6.000 3.000 5.000 4.0
Old Feb 4, 2011 | 01:21 PM
  #79
The_Scooch's Avatar
Who waits 20K to 30K miles to change an air filter? Crazy! I change mine when I change the oil at 3K. Buy a second filter and do it as swap. For all the focus and energy spent on 5 extra HP, it's hard to believe the laziness when it comes to maintenance. It's the care that keeps it powerful!
Old Feb 9, 2011 | 01:24 PM
  #80
Jeff92se's Avatar
Red Card Crew
No one really does that. I usually cleaned my K&N every 10k or so.
I used to be pretty gung ho about the dry cleanable dry filters (I run the Amsoil ea panel) but Dave B mentioned it eventually got clogged up after about 30k despite him cleaning it per the instructions. I'll just go back to my K&N or just use oem paper units and replace every 10k or so.
Old Jan 20, 2014 | 05:53 PM
  #81
madmang0's Avatar
How did you get the aluminum ring to fit inside the k&n filter. Mine is the Stillen kit but im stuck at trying to put the aluminum ring inside the filter. It seems my ring is too big.
Old Apr 22, 2017 | 10:09 PM
  #82
cullyisgully's Avatar
Any word on the K&N replacement filter to fit the stillen ?
Old Apr 23, 2017 | 04:26 AM
  #83
theronz's Avatar
I did not read the this thread but why K&N and not switch to a dry, non-oiled filter like AEM or R2C? Your MAF and throttle body will thank you.
Old Apr 24, 2017 | 01:18 PM
  #84
<br /><br />They said the dry one or AME doesn't fit you have to modify it to fit and I was seeing if there's one out there that you don't have to modify because I have the same exact intake on my G35
Old Apr 25, 2017 | 05:05 AM
  #85
theronz's Avatar
http://www.r2cperformance.com/black-...l-filters.aspx
Measure yours and find one close enough?
Old Apr 25, 2017 | 06:42 AM
  #86
Blue Dream's Avatar
I drove ttrank's car solo
If you would have read this thread you'll see that the R2C filter will fit only if you trim the front of the Stillen box. It's too big to fit without modifications.
Old Apr 25, 2017 | 10:09 AM
  #87
Im not trying to MOD my box looking for something to just fix with out modification
WiWil anything fit with out doing mod ?
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
