I found this post on an evo 8 forum on the net, it shows how to make easy nonfoulers for test pipes. I bought used set today and I only got one non fouler, $5 is cheap for what someplaces are charging for these little spacers. Heres the link:
http://forums.evolutionm.net/showthread.php?t=215795
Be careful with those non foulers I am almost certain that the 42009's are to shallow for the O2 sensor probe. We have always used 42002...Originally Posted by in2win
I found this post on an evo 8 forum on the net, it shows how to make easy nonfoulers for test pipes. I bought used set today and I only got one non fouler, $5 is cheap for what someplaces are charging for these little spacers. Heres the link:http://forums.evolutionm.net/showthread.php?t=215795
Tony
Tony
thanks, It looks like he used two double stacked though? Ill check if I try it, info is GREATLY appreciated
they shouldnt cost that much from kragen, pepboys, autozone, etc.
there is a diy in out forum for non-foulers.
less than $5?? Its basically $5 per side because you have to double stack them. Ill be doing this as soon as I get my new engine from Infiniti Riverside.
These are extremely cheap to make. I made a setfor my S4 with no cats and they worked perfectly. Go to Pepboys or Autozone and purchase the correct size Spark Plug Non-Foulers. You may have to drill them out a little for the O2 to fit in.
