Z Tube/Pop Charger vs. Z Box vs. Other CAI's
Old Apr 7, 2004 | 09:56 PM
g35funk's Avatar
I'm slowly learning about engine mods and wanted some feedback. Yes, I've been searching the forums for information but I'm trying to compare the Z Tube/Pop Charger setup versus other CAI's. Also, a Z owner mentioned to me that CAI's are prone to sucking water based on the mounting position, etc. He suggested seeing if the stock Z tube/box setup would fit instead. Is this even possible?
For reference, I'm looking for easy and relatively inexpensive mods to start with. I have access to the free Z tube/box setup if it works. If not, then perhaps adding the Pop Charger to the free Z tube is an option...assuming it is just as good as other CAI setups.
Thanks for any info you can provide...
Old Apr 7, 2004 | 10:54 PM
jjellyneck's Avatar
Re: Z Tube/Pop Charger vs. Z Box vs. Other CAI's
Add the Z tube for sure. It helps ever so slightly at the top RPM's. The JWT Pop charger will make more noise, and many say that it indeed adds maybe 5-6 hp at the upper RPMs also. That might be the best intake combination available.
jjellyneck
Old Apr 7, 2004 | 11:05 PM
Gordgee's Avatar
Administrator
You can fit the Z-tube directly onto the stock G35 air-box and add a K&N panel filter. Works well, and based on my 0-60 run times on a G-Timer, works better than with the Pop-Charger, and my Dyno results over 2 days (with Pop-Charger, then stock box) Pop-Charger results inconclusive?
I haven't decided yet whether I'm going to re-install my Pop-Charger, though I like the look and sound.
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Old Apr 8, 2004 | 03:22 AM
klg35's Avatar
easy and inexpensive? how about 5 minutes and free, check it out:
https://g35driver.com/forums/showfla...sed&sb=5&part=
compliement it with a k&n panel filter + z tube, then listen to it growl!.....have fun.
04 Black Sedan 6mt / front blinker mod, z tube+k&n panel filter / 18" r/h c2s w/khumos 235/40zr18 / stock airbox mod / s-teins / crank pulley / pre-muffler, what pre-muffler?
[image]url[/image]
Old Apr 8, 2004 | 07:16 AM
g35funk's Avatar
Great. Thanks for the information. One or two more questions:
If installing the Z tube, what exactly am I installing? Just the straight tube shown at the top here? Or will I actually install the additional piece connected to the G tube? (shown at the bottom of this picture)
https://g35driver.com/g35albums/album33/16_G.jpg
Thanks...sorry if this is a newb question...usually I'm more focused on wheels, etc.
Old Apr 8, 2004 | 10:01 AM
suzook's Avatar
you can also try my mod to the factory gtube for free here is the link https://g35driver.com/forums/showfla...t=1#Post224300
03.5 briliant silver/graphite
5at,sport,full aero kit,winter pack
bose.tweet upgrade
Old Apr 8, 2004 | 01:52 PM
klg35's Avatar
yep, it's that straight tube on top of pic.....if you have access to a free z-tube, then by all means, get it!!!!! if not,do the intake tube mod from Suzook. have fun, then enjoy your new "sound". never be sorry for asking, we're newbies once, i still am.....and wheels you say, try this......235/40/zr18s...it'll be 3.5% smaller in diameter than stock setup, side effect: engine is less strained as it's thinking its moving a "smaller" tire......hope that makes sense.
[image]url[/image]
Old Apr 9, 2004 | 07:45 AM
g35funk's Avatar
thanks for the info. so you think it might make sense to just do the Z tube first, then add a pop charger if necessary?
did anyone ever determine if the whole Z tube/box would fit a Z or if it's even worth it?
thanks again for the info everyone...
Old Apr 9, 2004 | 12:04 PM
Hey_Ya's Avatar
I still have a Z box from my old Z and I think the G's intake gets more air to it that the Z... Just my opinion.
2004 Diamond Graphite Infiniti G35 Sedan
Z Intake Tube
5% Tint
ZAINO
Old Apr 9, 2004 | 01:18 PM
g35funk's Avatar
Hmm. So again, perhaps it's a good start to try the Z tube first, then add a pop charger if necessary.
Thanks again for the feedback...
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
